- Portable Headphone Amplifier -
The Topping NX1A offers an easy-to-use and extremely efficient solution to give your headphones a whole new dimension.
The NX1A features quality components, designed to offer you optimal performance. Thus, you find WIMA and EPCOS capacitors as well as an ALPS potentiometer. The connector, the switch or the PCB have also beengilt.
If the NX1A keeps what has made the success of its predecessor the NX1, namely its excellent sound, it brings a significant advantage: extended autonomy. Thus, its 1000mAh battery will allow you to use for 150h, a 50% improvement!
More than that, the NX1A needs only 3 hours of charge to be fully charged. No time to wait? 5 minutes are enough to guarantee you a use for about 10h.
With the switch on the rear of the amplifier, you can precisely adjust the gain tonoise and improved sound reproduction.
Designed with precision CNC control, the NX1A housing is made entirely of black aluminum. Its matte surface and laser engravings offer a modern and elegant design.
CONNECTORS
Analog Input:
Headphones:
SPECIFICATIONS
VARIOUS
