XDUOO XD05T Portable DAC Tube Headphone Amplifier
The xDuoo XD05T portable DAC and headphone amplifier is a high-performance device where cutting-edge technology meets vintage. Indeed, it's based on the use of tubes machined in the 60s, coupled with transistors for its amplification circuitry, while the digital-to-analog conversion stage uses two ES9039Q2M DAC chips, an XMOS XU316 USB interface and an FPGA.
By buying this product you get 54 loyalty points
Reference : 20232
549,00 €tax incl.
457,50 € tax excl.
Shipping date: 29-04-2025.
xDuoo XD05T Portable DAC Tube Headphone Amplifier 2xES9039Q2M XMOS Bluetooth 5.1 32bit 768kHz DSD512 MQA Green
Photo du XDUOO XD05T
The xDuoo XD05T portable DAC and headphone amplifier is a high-performance device where cutting-edge technology meets vintage. Indeed, it's based on the use of tubes machined in the 60s, coupled with transistors for its amplification circuitry, while the digital-to-analog conversion stage uses two ES9039Q2M DAC chips, an XMOS XU316 USB interface and an FPGA. This little jewel of hybrid technology is therefore able to drive headphones with impedances from 32Ω to 300Ω without difficulty, while offering a soft, warm texture. What's more, it supports high-resolution sampling rates up to PCM 32Bit 768kHz, DSD512 and MQA x8 via its USB-C input.
The XD05T also boasts full connectivity, with a coaxial / Mini-Toslink optical input, a 3.5mm jack auxiliary input/output, a balanced 4.4mm jack input/output and, of course, two single-ended 6.35mm jack and balanced 4.4mm jack headphone outputs. Added to this are a range of operating modes, allowing it to be used as a desktop DAC/headphone amplifier, as well as Bluetooth 5.1 functionality thanks to a Qualcomm QCC5125 chip for great versatility of use. In terms of appearance, xDuoo has chosen a green chassis and gold-colored details to highlight the vintage spirit of its device.
xDuoo XD05T: A tube amplifier circuit
xDuoo has opted for authenticity by integrating tubes from a sixties production, offering a sound texture full of emotion, soft and warm, that will delight the most nostalgic. The use of these tubes also offers a wider dynamic range, greater than or equal to 116dB for the balanced 4.4mm jack headphone output and 114dB for the single-ended 6.35mm jack headphone output. The final sound reproduction is therefore rich in detail, immersive and provides a natural timbre.
Tubes du XDUOO XD05T
xDuoo XD05T: A high-performance hybrid structure
As for the xDuoo XD05T's amplification stage, the tubes are then coupled to a pair of transistors providing the necessary signal power to drive a wide range of headphones or earphones. Indeed, on its balanced 4.4mm jack headphone output, the xDuoo XD05T is capable of delivering up to 1500mW at 32 ohm and 565mW at 300 ohm. As for the digital-to-analog conversion stage, it relies mainly on two ES9039Q2M DAC chips and an XMOS XU316 USB interface, enabling it to support high-resolution sampling rates up to PCM 32bit 768kHz and DSD512 via its USB-C input.
La structure du XDUOO XD05T
Les réglages de gain du XDUOO XD05T
xDuoo XD05T: 3 gain settings
The xDuoo XD05T benefits from 3 gain settings, Turbo (L) perfect for IEMs, Turbo (M) for low-impedance headphones and Turbo (H) for high-impedance headphones. This allows it to adapt to a wide range of hardware configurations, and to deliver its best performance in all circumstances.
xDuoo XD05T: Bass enhancement function
The xDuoo XD05T features a switch to boost the bass in the sound reproduction for users who want a more immersive experience. This can also be useful depending on the source used.
Fonction d'amélioration des basses du XDUOO XD05T
xDuoo XD05T: Two operating modes
If you want to use the xDuoo XD05T in desktop mode, simply power it via its DC USB-C power port. Of course, it can also be used on the move, thanks to its internal 6000mAh battery, which provides excellent autonomy.
Les modes de fonctionnement du XDUOO XD05T
xDuoo XD05T: 99-level volume adjustment
On one side of the xDuoo XD05T, there's a potentiometer for adjusting the output volume over 99 levels, for precise setting whether low or high volume is required.
Ajustement du volume du XDUOO XD05T
xDuoo XD05T overview
XDUOO XD05T overview
1Single-ended Jack 6.35mm headphone output
2Balanced Jack 4.4mm headphone output
3Display
4Power on
5Turbo function
6Bass boost function
7DC power supply
8Coaxial / Optical Mini Toslink input
9Operating mode selection
10USB-C input
11Jack 3.5mm input/output
12Jack 4.4mm input/output
Product typePortable DAC headphone amplifier
DAC chipESS ES9039MSPRO
USB interfaceXMOS XU316
Bluetooth chipQCC5125
Inputs1x USB-C
1x Coaxial / Optical Mini Toslink
1x AUX input/output jack 3.5mm single-ended
1x AUX input/output jack 4.4mm balanced
Outputs1x Single-ended 6.35mm jack headphone output
1x Balanced 4.4mm jack headphone output
Supported sample ratesPCM up to 32bit 768kHz, native DSD up to DSD512 and MQAx8
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
OS compatibilityWindows, Linux, Mac OS, IOS, Android
Output power750mw @ 32 ohm (THD+N>5%)
83mW @ 300 ohm (THD+N>5%)
Output impedance< 0.2 ohm
Peak voltage15Vp-p (Turbo)
Frequency response20Hz-20KHz (±0.5dB)
Crosstalk≥ 75dB
THD+N0.5%
SNR≥ 114dB
Output power1500mw @ 32 ohm (THD+N>5%)
565mW @ 300 ohm (THD+N>5%)
Peak voltage26Vp-p (Turbo)
Frequency response20Hz-60KHz (±0.5dB)
Crosstalk≥ 105dB
THD+N0.5%
SNR≥ 116dB
Single-ended Jack 3.5mm AUX output
Output level2.0Vrms
THD+N0.00065%
SNR≥ 120dB
Crosstalk≥ 100dB
Balanced Jack 4.4mm output
Output level4.0Vrms
THD+N0.00065%
SNR≥ 124dB
Crosstalk≥ 100dB
Power supply12V DC (desktop mode) or battery
Circuit protectionOverheating
Overload
DC protection
Battery3.7V / 6000mAh
Battery operating timeUSB/SPDIF: 4h
AUX: 4.5h
Charging time3.5h (fast charge)
10h (slow charge)
Dimensions168 x 78 x 23mm
Weight400g
Package1x xDuoo XD05T
2x USB-C to USB-C cable
1x USB-C to Lightning cable
1x USB-C to USB-A adapter
1x 3.5mm jack to 6.35mm jack adapter
InputJack 4.4mm
InputJack 3.5mm
InputMini Toslink 3.5mm
OutputJack 3.5mm
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipES9039Q2M
Max sampling rate768kHz
Max sampling rateDSD512
ColorGreen
ClassN/A
XDUOO XD05T Portable DAC Tube Headphone Amplifier 2xES9039Q2M XMOS Bluetooth 5.1 32bit 768kHz DSD512 MQA Green
The xDuoo XD05T portable DAC and headphone amplifier is a high-performance device where cutting-edge technology meets vintage. Indeed, it's...
