XDUOO XQ-23 Headphone Amplifier DAC WM8955 Bluetooth aptX CSR8670
The xDuoo XQ-23 presents itself as a combo Amplifier and DAC, integrating the Bluetooth and thought especially for a nomad use. Indeed, its versatility and compactness will allow you to take it with you everywhere, on the road or at work.
Reference : 12784
47,90 €tax incl.
39,92 € tax excl.
xDuoo XQ-23
Headphone amplifier DAC WM8955 Bluetooth aptX CSR8670
xDuoo XQ-23 Amplificateur Casque
No need for cable
Probably one of the main assets of this XQ-23, Bluetooth integration. Indeed, thanks to it no more need of cable during your displacements. Moreover, in version 4.1, it ensures a fast and stable data transfer, for a quality sound reproduction. In the same spirit, xDuoo chose to integrate a Bluetooth CSR8670 chip supporting the aptX protocol. This allows a very good transmission quality with a data rate of approximately 350Kbit/s. Ideal to enjoy your music.
In addition, for those with a single port for audio and charging on their smartphone, it becomes possible to charge their smartphone while enjoying the amplifier via Bluetooth.
A really compact amplifier
Another strong argument of the XQ-23: its format. Indeed, extremely compact with its format USB key, it slips without problem in a pocket. Designed to follow you everywhere, it will soon be forgotten, without compromising its sound performance.
xDuoo XQ-23 Amplificateur Nomade
xDuoo XQ-23 DAC
High-performance D/A decoding with the DAC WM8955
The XQ-23 integrates a Wolfson WM8955 chip serving both as an amplifier but also as a DAC, particularly suitable for mobile equipment. This ensures very good audio reproduction, close to CD quality.
The DAC can also be used in USB, in order to benefit from its conversion on other peripherals, such as a computer for example.
Make your voice heard
The small xDuoo amplifier also incorporates a convenient front microphone feature. Thanks to its Bluetooth CSR8670 chip with a noise reduction function, the XQ-23 offers a more efficient voice reproduction quality, similar to that of a smartphone. In addition, the aptX Bluetooth protocol provides superior signal stability, which only improves transmission.
Supports two devices at once
The XQ-23 allows two devices to be connected simultaneously via Bluetooth. Thus it becomes possible, for example, to pair your smartphone to receive calls while associating a tablet as a music source.
Small but strong
As a mobile device, the XQ-23 must be rugged. That's why xDuoo integrates its amplifier into a beautiful, high-precision CNC machined aluminum alloy housing. A case that also gives it an elegant and original design.
À noter également, la présence d'une large LED en haut de l'appareil, permettant d'afficher son état :
  • Blue LED = Connected state
  • Blinking red LED = batterie faible
  • Blue to green breathing cycle = Playing
xDuoo XQ-23 Design
Bluetooth version4.1
Bluetooth ProtocolsaptX, SBC, AAC
Distortion< 0.01%
Max Bluetooth transfer distanceAbout 10m
Impedance16~100Ω
Output power32mW @ 32Ω 1kHz THD+N < 1%
SNR>= 95dB
Battery autonomy>= 5h
Charging time< 1h
Housing materialAluminium
OutputJack 3.5mm
The xDuoo XQ-23 presents itself as a combo Amplifier and DAC, integrating the Bluetooth and thought especially for a nomad use. Indeed, its...
