MUNDORF MCONNECT Copper Foil Flat Wiring Cable 70x0.07mm 4.9mm²
This flat wire Mundorf will appeal to amateurs chevronés wishing to design cables loudspeakers or for the shielding by sheets of transformers, condensers or simply of boxes.
Reference : 12371
4,90 €tax incl.
4,08 € tax excl.
Câble au mètre
MUNDORF MConnect
Copper Foil Wiring Cable 70x0.07mm 4.9mm²
Mundorf MConnect Fil de câblage plat feuille de Cuivre 70x0.07mm
This Mundorf MConnect flat wire from the German manufacturer's Foil Coil coils offers many possibilities such as the DIY design of flat loudspeaker cables with low impedance and low inductance. It will interest the experienced DIY enthusiast who wants to manufacture high quality custom cables. This wire can also be used as an EMI/RFI shielding plate for transformers, components or chassis to combat eddy effects.
Product typeFlat wiring cable
MaterialOFC Copper (Pureté = 99.9997%) 70µ
Section4.9mm²
Width70mm
Thickness0.07mm
Diameter (mm)N/A
Length (m)Sold by length
Number of conductors1
Insulation materialNone
ShieldingNo
Section (mm²)4.9
Inductance (mh)N/A
Ground / ShieldingNo
Blindage coffret
J'ai fixé de l'amortisseur bitume à l'intérieur des capots des amplificateurs, préamplificateur et convertisseur puis j'ai fixé ces feuilles de cuivre comme un cadre de tableau sur le bitume. L'effet est intéressant: le blindage et le bitume apportent au son plus de netteté et de détourage.
This review has been posted for MUNDORF MCONNECT Copper Foil Flat Wiring Cable 70x0.07mm 4.9mm²
This flat wire Mundorf will appeal to amateurs chevronés wishing to design cables loudspeakers or for the shielding by sheets of...
