NEOTECH SOCT-12 Wiring cable Copper UP-OCC PTFE 3.3mm²
Neotech has long been the leader in cable production using UP-OCC "single crystal" copper developed by Professor Ohno of the Chiba Institute of Technology in Japan.
Reference : 9834
28,90 €tax incl.
24,08 € tax excl.
Shipping date: 23-04-2025.
NEOTECH SOCT-12
UP-OCC is 99.99998% pure.
UP-OCC is considered the "nec plus ultra" of conductors used today.
Characteristics:
  • Insulation : PTFE
  • Conductor : UP-OCC (99,99998% pure)
  • Internal diameter : 2.05mm
  • External diameter : 2.80mm
  • 12AWG / 3.3mm²
  • Color : Red
  • Sold by meter
https://www.audiophonics.fr/img/cms/products/8941/UPOCC-1.png https://www.audiophonics.fr/img/p/7/4/4/0/7440.jpg
Diameter (mm)2.8
Length (m)Sold by length
Number of conductors1
Insulation materialPTFE
ShieldingNo
Section (mm²)3.30
Ground / ShieldingNo
5 reviews
The Best Copper Wire in Earth For Hi-Fi
Don't be fooled by the the title "Wiring Cable" !! Use this wire in power and speakers cables. For power cable just enclose it to a hard hose not to bent and use pure copper plugs. Don't use any kind of shield!! For speakers cable twist it 7 twists per meter and use it without plugs or with good quality ones. This is the best audio cable, it beats cables costing many thousands. Companies just don't use it because of it's easy to bent character.
I have made many power and speakers cable using this wire for me and my friends. I have also build interconnect cables using SOCT 18 wire in pseudo-balanced configuration. In direct comparison with many expensive cables those cables have completely no sound character, no coloring, no hi-frequency harsh, excellent tonal unity and the best bass control. Don't use those cables to "tune" problematic sounding systems, these are completely neutral and transparent cables let you to hear your Hi-Fi/Hi-End gear.
This review has been posted for NEOTECH SOCT-12 Wiring cable Copper UP-OCC PTFE 3.3mm²
Exelent en straps sur bornier d enceinte
J ai confectionné quatre fils avec gaine coton et nylon pour la finition sur des viborg banane cu pl argent qui remplace mes straps de 4mm2 up occ multibrin. Resultat exelent. Grave plus dynamique et puissant plus riche en details. Monté croisé plus med aigus et moins grave. Allié au jmr 1120 cu arg. 2mm2. Equilibre tonal parfait. Plié en une courbe grande. Long des fils 20 cm.
Excellent
Un peu cher mais indispensable pour obtenir des résultats de qualité.
Best copper available
I have always preferred single core copper for audio and SOCT is the best I have used.
I'm refreshing a few amps that are in working condition but are getting old. Just for fun I put this 12AWG cable between the internal amp stage and speaker terminals. What a difference! The deep bass became very fluid and there is no hint of harshness in the high frequencies any more. The old wire was 18AWG tinned copper and I only make one change at a time to evaluate the effect. It's a stiff cable so of course you have to secure it for vibration by that is a small price to pay.
 (3)
Intéressant!
Ce type de câble donne une très bonne qualité de transmission partout où on l'utilise. Par exemple on peut l'entourer de gaine coton (pour s'inspirer de la mousse de polyéthylène), ce qui devrait donner un des meilleurs isolants qui soit! Pour les médiums/aigüe, peut-être utiliser plusieurs câble plus fin en parallèle...
Neotech has long been the leader in cable production using UP-OCC "single crystal" copper developed by Professor Ohno of the Chiba...
