NEOTECH SOST-30 Wiring Cable UP-OCC Solid Pure Silver PTFE 30AWG 0.0509mm²
Neotech, leader in high-tech HiFi cable, continues its research in the field of sound reproduction and today produces the ultimate in cabling wires. The SOST Solid Core Silver Wire series allows the manufacture of single-stranded cables made of the highest quality UP-OCC Pure Silver with a high level of PTFE dielectric insulation.
Reference : 14609
8,50 €tax incl.
7,08 € tax excl.
Shipping date: 25-04-2025.
Câble au mètre
Neotech SOST-30
You can now design cables in pure silver at home and set the standard for high-end audio cables. The process developed by Professor Ohno of the Chiba Institute of Technology of Japan raises the purity of the silver strand to 99.99998%, well above the level of standard cables.
The oxygen particles inside the silver strand are thus reduced to an insignificant level, ensuring a high level of stability over time and preventing oxidation over the long term.
Neotech SOST UP-OCC solder cables are available in various diameters and cross-sections, thus meeting all the expectations of informed amateurs wishing to design their own HiFi cables.
Comparaison structure OFC et UP-OCC
Product typeWiring cable
ConductorSolid pure UP-OCC Silver (purity = 99.99998%)
Section0.0509mm² (30AWG)
InsulationPTFE
Conductor diameterØ0.29mm
External diameterØ0.96mm
Rated voltage / current300V / 1.9A
ColorBlue
QuantityCable sold by the meter
Certificat de qualité et d'authenticité du professeur Ohno
Diameter (mm)1.0
Length (m)Sold by length
Number of conductors1
Insulation materialPTFE
ShieldingNo
Section (mm²)0.0509
Conductors material (Cable)Silver
Ground / ShieldingNo
3 reviews
Ethernet RJ45 Cable
Made Ethernet RJ45 Cable out of this to see what would happen. No shielding . Use it to stream Disney 4K and X Box games. had other pure silver cable from A-Phonics on it but this looks better to me. Once broken in this has a wow factor on the right material I have recently found out that NEOTECH SOST-28 Wiring Cable UP-OCC Solid Pure Silver PTFE 28AWG 0.081mm² will fit as well. Thanks A_F for your great company.
This review has been posted for NEOTECH SOST-30 Wiring Cable UP-OCC Solid Pure Silver PTFE 30AWG 0.0509mm²
Cable DC
Produit excellent. Triplé par pôle pour un câble DC pour un switch. Équilibré dynamique fluide et détaillé. Je recommande
Excellent pour un Diy Modulation
Utilisé pour réaliser un Diy modulation en RCA, le résultat est absolument sublime, attention la fragilité du conducteur oblige de trouver des solutions pour limiter la casse du fil, mais le résultat vaut qu'on se penche sur le problème.
Neotech, leader in high-tech HiFi cable, continues its research in the field of sound reproduction and today produces the ultimate in cabling...
