NEOTECH STDCT-18 Hook-Up Wiring Multi-Strands UP-OCC PTFE 0.8mm²
The STDCT cable wire is a very high quality multi-core cable with 99.99998% pure UP-OCC copper conductor and PTFE insulation. Ideal for efficient internal wiring.
Reference : 13358
11,90 €tax incl.
9,92 € tax excl.
Shipping date: 07-05-2025.
Neotech STDCT-18
Hook-Up Wiring Multi-Strands UP-OCC PTFE 0.823mm²
Neotech STDCT-18 Fil de Câblage Multi Brins UP-OCC PTFE 0.823mm²
Neotech has long been the leader in cable production using UP-OCC "single crystal" Copper developed by Professor Ohno of the Chiba Institute of Technology in Japan.
The UP-OCC is 99.99998% pure and is considered to be the "ultimate" conductor used to date. This STDCT-18 cable has a cross-section of 0.823mm² (18AWG) and consists of 19 wires of 0.25mm diameter.
Product typeWiring cable
ConductorUP-OCC Copper (Purity: 99.99998%)
Section0.823mm² (18AWG)
Strands number19 strands of Ø 0.25mm
InsulationPTFE
Internal diameter1.2mm
External diameter2.2mm
Voltage / Current600V 13.5A
ColorRed
Diameter (mm)
  • 2.2
Length (m)
  • Sold by length
Number of conductors
  • 1
Insulation material
  • PTFE
Shielding
  • No
Section (mm²)
  • 0.823
Conductors material (Cable)
  • Copper
Conductors Plating (Cable)
  • None
Ground / Shielding
  • No
4 reviews
very good product
This review has been posted for NEOTECH STDCT-18 Hook-Up Wiring Multi-Strands UP-OCC PTFE 0.8mm²
Excellent cable
Crystal clear and punchy sound. I use it for connecting the PSU with the phono preamp of a Lehmann silver phono.
Excellent produit !
Vraiment un excellent câble pour recablage de matériel hifi ou fabrication de câbles dc.
Personnellement je m'en suis servis pour le tweak de mon switch rj45 Cisco Meraki Ms220.
Super pour recâbler une enceinte !
Complément du commentaire que j'ai laissé sur le câble de 1,3 mm² et concernant le recâblage d'une enceinte Focal Electra 1008 Be II. J'ai utilisé le câble de 0,8 mm² pour relier, en parallèle du câble de 1,3, le bornier et le filtre. Ceci pour accroitre la section à 2,1 mm² et mixer les sections des brins. Puis j'ai relié le tweeter avec le 0,8 mm² seul. J'avais en plus changé les condensateurs du filtre et le bornier pour un Mundorf. Toutes les connections sont désormais soudées. Le tout transfigure ces enceintes qui deviennent beaucoup plus expressives et fouillent les détails de la musique avec réalisme et conviction. Je suis ravi de ma transformation et de ces câbles qui mettent apporte un réel bénéfice à l'écoute.
The STDCT cable wire is a very high quality multi-core cable with 99.99998% pure UP-OCC copper conductor and PTFE insulation. Ideal for efficient...
