Wiring Cable Silver Plated OCC Copper PTFE Sheath 0.2mm² Ø1.1mm Transparent
This Ø1.1mm wire has a silver-plated OFC copper conductor with a cross-section of 0.2mm². This ensures high conductivity. The entire assembly is covered with a transparent, high-temperature-resistant PTFE insulating sheath
Reference : 18694
1,90 €tax incl.
1,58 € tax excl.
Shipping date: 25-04-2025.
Cable sold by the metre
Wiring cable Silver Plated OCC Copper PTFE Sheath 0.2mm² Ø1.1mm Transparent
0.2mm² OFC copper wire, silver plated
This Ø1.1mm wire has a silver-plated OFC copper conductor with a cross-section of 0.2mm². This ensures high conductivity. The entire assembly is covered with a transparent, high-temperature-resistant PTFE insulating sheath. This cable is ideal, for example, for DIY use as a signal cable, or for internal wiring of HiFi equipment.
Technical characteristics
Product typeMulti-strand wiring cable
Conductor materialOCC copper
InsulationPTFE sheath
Number of strands7 x 0.2mm
Conductor section0.2mm² (AWG24)
Cable diameterØ1.1mm
Temperature resistance300°C
Max. voltage600V AC
ColorTransparent
QuantitySold by the metre
Diameter (mm)1.1
Number of conductors1
Insulation materialPTFE
ShieldingNo
Section (mm²)0.2
Ground / ShieldingNo
Occ ou Ofc
Dans le descriptif il est indiqué que c'est du fil occ, puis vous stipulé ofc.
Quelle est la vraie nature de ce fil svp ?
Bonjour,
L'OCC (Ohno Continuous Cast) est une technologie et l'OFC une pureté (Oxygen Free Copper), un conducteur peut parfaitement être les deux à la fois.
This review has been posted for Wiring Cable Silver Plated OCC Copper PTFE Sheath 0.2mm² Ø1.1mm Transparent
This Ø1.1mm wire has a silver-plated OFC copper conductor with a cross-section...
