Wiring Cable Silver Plated OCC Copper PTFE Sheath 1.5mm² Ø2.1mm Transparent
This Ø2.1mm wire is made of silver-plated OFC copper with a cross-section of 1.5mm². This ensures high conductivity. The whole assembly is covered with a transparent, high-temperature-resistant PTFE insulating sheath.
Reference : 20370
9,90 €tax incl.
8,25 € tax excl.
Cable sold by the metre
Wiring cable Silver Plated OCC Copper PTFE Sheath 1.5mm² Ø2.1mm Transparent
1.5mm² OFC copper wire, silver plated
This Ø2.1mm wire is made of silver-plated OFC copper with a cross-section of 1.5mm². This ensures high conductivity. The whole assembly is covered with a transparent, high-temperature-resistant PTFE insulating sheath. This cabling wire is ideal, for example, for DIY use as a signal cable, or for internal wiring of HiFi equipment.
Technical characteristics
Product typeMulit-strand wiring cable
Conductor materialOCC copper
InsulationPTFE sheath
Number of strands19 x 0.32mm
Conductor section1.5mm²
Cable diameterØ2.1mm
Temperature résistance300°C
Max. Voltage600V AC
ColorTransparent
QuantitySold by the metre
Diameter (mm)2.1
Number of conductors1
Insulation materialPTFE
ShieldingNo
Section (mm²)1.5
Ground / ShieldingNo
This Ø2.1mm wire is made of silver-plated OFC copper with a cross-section of 1.5mm². This ensures...
