ARMATURE ELECTRA F6 V2 Filtered Power Distributor 6 Sockets Aluminium Black
The Electra F6 V2 Armature is a high quality filtered mains distributor, integrating two direct and four filtered outlets that will give your music its true color.
KEY POINTS :
  • OCC Copper
  • CLC filter
  • 2500W 10A
  • Gold plated contacts
  • 2 Direct taps without filtering
  • 4 CLC EMI / RFI filtered outlets
Reference : 12356
199,00 €tax incl.
165,83 € tax excl.
ARMATURE ELECTRA F6 v2
Filtered power mains distributor 6 outlets
Distributeur secteur filtré Armature Electra F6
An essential hifi element
The mains power is the first link in your Hifi system. It is essential to offer for your Hifi system a stable and clean voltage devoid of any harmonic distortions. It is in this sense that Armature has developed Electra, a range of innovative sector distributors offering two modes of operation.
Distributeur secteur Armature Electra
Filtered Mode and Direct Mode
To suit all needs and systems, this Electra F6 V2 integrates 2 outlets in Direct mode for your power amplifiers. These 2 gold-plated sockets respects the rhythm of the music without the effects of dynamic compression. The Electra F6 also has 4 CLC filtered outlets that effectively lower the potential interference (RFI, EMI) that could affect the sound reproduction of your audio system. The internally cable are only 2.5mm² OCC copper. The result is convincing : your system widens its dynamic range to assert itself in the bass and treble mediums become more accurate, more natural and offering a great respect of harmonics ..
Mode direct et Mode filtré
A high quality filter
To achieve this feature, the Armature Electra F6 mains distributor incorporates an oversized CLC-type power filter, consisting of WIMA film capacitors and a custom Tore Ferrite choke, to divide AC mains distortion by 8 (dependent on the quality of your mains installation). In addition, all contacts are Gold plated to ensure excellent signal conductivity.
Des composants de qualité
A secure system
The Electra Power Distributor is capable of supporting up to 2500W over 10A and features a resettable circuit breaker to protect your HiFi system..
Armature Audio Distributeur secteur Electra
TypeFiltered mains distributor with OCC 2.5mm² copper cable
Connectors number6 (2 direct + 4 filtered CLC)
Type of filterCLC (Wima capacitors and ferrite tore)
Maximum power2500W 10A
ContactGold plated
Box materialsAluminium + 4 rubber feet
Dimensions33.5 x 15.5 x 6.8cm
Weight1.9kg
Accessories1x IEC cable 1.5m
Number of sockets6
FilteringYes
4 reviews
Excellent !
Beau distributeur et belles finitions. Il est plutôt grand et fait son poids. Aucune radiation autour du boîtier, ni sur les prises. Le filtrage est de qualité. Il n’en fait pas trop et apporte une belle sonorité naturelle. Belles basses, belle aération, aigus assez doux et détaillés. Bel équilibre. Quatre prises filtrées c’est déjà bien et c’est appréciable d’avoir deux prises non filtrées pour des amplificateurs sur un bon distributeur. Bouton power bien placé sur le devant, joli, discret et très utile. 5/5
This review has been posted for ARMATURE ELECTRA F6 V2 Filtered Power Distributor 6 Sockets Aluminium Black
Satisfait
La qualité de fabrication est plus que satisfaisante et propre pour cette gamme de prix.
Bien sur les puristes vont critiquer l'interrupteur, mais bien pratique pour garantir une mise hors tension. Associé à 2 câbles PANGEA AC-14SE MKII, un pour remplacer l'alimentation du bloc, l'autre pour mon ampli Lector audio ZXT70. La section de ces 2 câbles laisse passer largement le courant nécessaire à ma configuration.
Pour le gain à l'écoute je vais éviter de faire un commentaire à court terme sur ce sujet subjectif.
Satisfait
Oui Satisfait
Effectivement cette barrette Electra est d’une bonne fabrication après déballage
J’ai démonté la plaque inférieur pour y regardé la fabrication qui est de bonne facture.
Le câble fourni avec mériterai d’être changer pour un bon câble d alimentations.
Niveau gain de son bon là malheureusement il ne faudra pas s’attendre à un miracle !!!
Je note quand même qu’il a une amélioration des basse et des médiums, au niveaux de gains de puissance ou pèche rien de rien de plus .
Après sa ne peut que augmente la qualité de votre système hifi donc à ce prix n’existe pas.
Mon matériel ampli marantz pm 11sa avec le lecteur cd 11sa enceinte focal sopra n2 câblage esprit
Très satisfait !
Ce produit semble robuste, construit avec soin et faisant appel à des matériaux sérieux.
Le poids et les dimensions sont conséquentes. Je précise qu il dispose d un interrupteur. Quant au rendu sonore, je ne m attendais pas à un miracle... Et c est effectivement le cas, mais j ai fait beaucoup de changement sur mon installation plus ou moins en même temps que l ajout de cette mutliprise, et je ne dispose pas d un ensemble tres haut de gamme. En faisant des comparatifs précis, il y aurait peut être moyen d entendre des différences avec une multiprise Casto à 20€...
The Electra F6 V2 Armature is a high quality filtered mains distributor, integrating two direct and four filtered outlets that will give your music...
