AUDIOPHONICS MPC6 V2 Power distributor 6 ports Aluminum FURUTECH Black
4.8 / 5
By buying this product you get 42 loyalty points
Reference : 11582
429,00 €tax incl.
357,50 € tax excl.
Shipping date: 15-04-2025.
The Audiophonics MPC6 V2 represents the next generation of high-end power strips. The Audiophonics MPC6 V2, with a revised and corrected finish with rounded fingernails and improved mechanical strength, offers great possibilities for optimization.
This new generation MPC6 V2 features a new aluminum finish with rounded corners for better finishing and increased electromechanical performance.
Throughout the process of creating this product the emphasis has been placed on the choice of materials so as to obtain one of the best possible interconnections sector.
Thea connectic is integral of source FURUTECH and processed with the famous Alpha process, the ELECAUDIO wire has been retained for its monocrystalline OCC copper, its PTFE insulation and its very low impedance. The retained tips allow better contact and increased protection against corrosion, aluminum housing has been selected for its massiveness, inertia and robustness.
Here are the IEC, Schuko, and wiring jacks used for the Audiophonics MPC6 V2:
Sockets Schuko:
IEC socket:
Wiring:
Chassis Thickness :
  • Facades: 3.5 mm
  • Sides: 3.5 mm
  • Top: 8mm
  • Bottom: 3 mm
Characteristics:
  • 6 plugs Schuko FI-E30 Pure gold plated copper
  • IEC FURUTECH FI-06 connector
  • Anti-slip rubber feet
  • Dimensions (in mm): 340 x 123 x 75 (W x W x H)
  • Weight: 2.2kg
  • Black color
- Wiring diagram MPC6 V2 -
Schéma de câblage DISTRIBUTEUR SECTEUR MPC6 V2
Number of sockets6
FilteringNo
5 reviews
Excellent rapport qualité prix
La barrette montée est vendue au prix des différents composants également dispo sur le site, sans supplément pour le montage donc. Bravo Audiophonics !
En gros, Audiophonics nous offre la barrette que Furutech aurait du nous proposer à prix raisonnable.
Je regrette quand même la section assez fine du câble. Ce serait possible de mettre du câble plus qualitatif sans faire exploser le budget, comme c'était le cas d'ailleurs sur une ancienne version de cette barrette qui n'est plus dispo.
Avec les embases schucko furutech or, on a un son plaisant, chaleureux avec des basses costaud, mais le tout est assez rond, pas ce qu'il y a de plus transparent et dynamique. J'ai finalement préféré la barrette whynot à 800/900 euros, plus neutre (mais là on perd en RQP). Sur pas mal de systèmes, je suis persuadé qu'on pourra préférer le modèle audiophonics.
Vu les prix pratiqués sur ce genre d'accessoire, y compris par les spécialistes Oyaide et Furutech, Audiophonics pourrait proposer une barrette vraiment haut de gamme pour moins de 1000 euros. En mettant deux ou trois embases oyaide swx par exemple. Une furu rhodium pour varier les plaisirs. Et le reste en furutech or qui font le job pour les appareils qui n'y sont pas trop sensibles.
Le très joli boitier audiophonics à 119 euros se retrouve sur des modèles complètement délirants à 5000 euros (Audiophonics devrait réclamer une commission! :) )
This review has been posted for AUDIOPHONICS MPC6 V2 Power distributor 6 ports Aluminum FURUTECH Black
Le Top
Que dire? Rien à part pourquoi j'ai pas fait cette achat beaucoup plutôt great Job Audiophonics et merci encore!!
Bien fait, et beau
Ça respire la solidité. Bien stable.
Great product! great improvement of sound!
I was not lucky to order just before the covid crisis, so I received it late. Audiophonics were nice to propose alternatives but I waited.
Received a few days ago. I alreday love it. Nice build quality (I ordered also the phase tester just in case). very solid and nice.
In replacement of standard very good distributor. I am using it with an Atoll IN200 driving a pair of Kef R900 and with furutech OCC cables. The sound is more "airy" (can we say that?), and background more dark. The Kef kept the low frequencies but look less boomy. Next investment could be the amplifier who is fantastic now up to 40/100 volume, but not enough strong to drive the Kef after that already decent volume.
Solid quality
The power distributor is solidly built and wired in a star shape. All plugs are firmly seated in the sockets. Recommended.
