BADA LB-6610 8-Port Schuko Gold Plated Gold Plated
Reference : 5587
499,00 €tax incl.
415,83 € tax excl.
Shipping date: 22-04-2025.
This high performance mains filter with 8 Schuko plugsin the European format it is possible to reverse the direction of connection in order to respect the phase of each connected device. It brings great improvements to the listening without dynamic compression (pumping effect) or hardness in the acute medium. This new generation includes 8 Schuko gold plated.
This Schuko 8-port mains filter also exists in black version: BADA LB-6610 Black.
How to connect the BADA 6610?
  • Line 1 out of 4 outlets to connect the sources of low consumption: CD players, Blu Ray players, Tuners, DAC, Streamer Audio, Turntables, Internet Box, NAS, Laptop, PC
  • line 2 out of 4 sockets allows to connect the devices with stronger currents: Integrated amplifiers, power amplifiers, HC amps, Subwoofer, active speakers.
Technical specifications:
  • Progressive filtering in a CLC network by means of winding coils on toroid and gap, and WIMA MKP capacitors.
  • Internal wiring made from 2.5 mm² OCC monocrystal copper conductors for better electrical distribution and significant sound gain.
  • General Overvoltage Circuit Breaker with Reset Switch accessible on the rear panel.
  • Detachable mains cable on IEC 3-pole base for personalization or upgrade.
  • Highly accurate digital voltmeter (ATMEL) Red display on the front Frame with thick aluminum fronts (8 mm).
  • Line selector to activate the supply of the elements separately
    Ex: Possibility of connecting the sources on line 1 and the amplification elements on line 2
Specifications:
  • Number of Gold-plated Filters: 8
  • Maximum Power Rating: 3300W / 15A
  • Input Voltage: 220V / 240V
  • Total Dimensions: 340 x 180 x 100 (L x W x H)
  • Weight: 5Kg
  • Standard power supply cable 1m50 long
Number of sockets8
FilteringYes
5 reviews
Excellent rapport qualité prix
Produit de tres belle qualité , avec comme atouts :
une ligne filtré pour l'élètroniques et une non filtré pour les amplis, des contact Or , 1 interupteur par ligne tres pratique, un voltmetre de couleur bleu sympa.
Le rendu au niveau son est long pour ce faire entendre (rodage), mais il est bien present !
This review has been posted for BADA LB-6610 8-Port Schuko Gold Plated Gold Plated
La fabrication c'est du costaud !
Pour le rendu sonore je constate une nette amélioration sur tout les registres en comparaison de ma petite FURUTECH.
SUPERBE!
Beau matériel, bien pensé. Belle plénitude. Livraison hyper rapide.
Emballage top: Audiophonics oblige !
Barrette BADA porte avions
Très belle barrette, pour info les côtes gauche Et droite sont en tôle finition aluminium, le voltmètre et bien en couleur bleu et non pas rouge En indiquant 243/248 Volts ( merci EDF
Excellent produit qui apporte un gain qualitatif évident(douceur,aération,richesse des
timbres,scène sonore large et profonde et son "holographique"). La qualité de fabrica-
tion est hors de critique et le prix très étudié au regard du très bon niveau de ce
produit.
Merci également à toute l'équipe du site Audiophonics pour leur sérieux et leur
professionnalisme(plusieurs commandes et aucun problème).
 (3)
