DIY Aluminum 4 ports Schuko Power Strip Black
4.2 / 5
Reference : 3450
45,90 €tax incl.
38,25 € tax excl.
Shipping date: 25-04-2025.
DIY Power Strip
Aluminium, 4 Schuko Ports, Black
Multiprise DIY Aluminium 4 Ports Schuko Noir
This DIY 4-port Schuko grounded power strip has a very good design quality, ideal for cleanly powering a HiFi audio system. The power supply rails are made of Copper alloy with large sections (about 6mm²) ensuring a very good conductivity. All components are integrated in a robust black aluminium housing.
The great feature of this power strip is that it is delivered without mains cable, so that you have the choice of this important element.
This power strip is supplied without mains cable, which must be purchased separately. For many high-end power cables, the cable entry of the power strip will need to be enlarged to 9mm diameter.
Product typeDIY Power strip
Number of Schuko plugs4
Ground
Conductor rails materialCopper alloy (Brass)
Case materialAluminium + Plastic (power strip tip)
Dimensions (LxWxH)270 x 60 x 45mm
Origin of manufactureGermany
Power cableSold separately, to be assembled
Weight900g
Dismantling the power strip
The method of disassembling the mains cable for installation of the mains cable is as follows:
      Dismantle the 4 Schuko sockets by removing the central screw on each one.
      Open the power strip in 2 by separating the upper and lower parts of the socket.
      Unscrew the ground nut inside the power strip. This will allow you to slide the plugs.
      Once the first plug has been removed, you will find a terminal block with a screw on the top of the rails.
Number of sockets4
FilteringNo
10 reviews
Très bien
Une barrette bien conçue la mise en œuvre est facile (merci pour les explications)avec un bon câble le produit est à la hauteur …
This review has been posted for DIY Aluminum 4 ports Schuko Power Strip Black
Bonne qualité
Multiprise de bonne qualité mais le montage du câble secteur n'est pas évident...j'ai bien mis 2 heures pour
monter cette satanée Multiprise !!
Un petit tutoriel serait le bienvenue
Le branchement des deux cosses Ph & N n'est pas très génial et empêche de remettre la prise la plus proche. J'ai préféré souder ces deux fils au milieu de chaque barrette. Une fois cette modif faite, bon produit.
A ce prix, il n'y a rien d'autre d'aussi sérieux...But you must Do It Yourself.
Casse tête
Belle fabrication, restituton en fonction du câble choisi, robuste, peu encombrant, excellent prix.
Mais un casse tête à démonter et à remonter, un enfer. Simplissime sûrement pour la deuxième, mais que de temps et d'agacement pour y arriver, je déconseille ++ . Il existe une version supérieure et montée... Plus jamais ça.
Il suffirait seulement d'avoir un vrai schéma de démontage et de câblage fourni ...
PS je suis une personne calme et minutieuse.
