DYNAVOX X2000 Filtered Power Strip 5 Schuko Sockets with Master-Slave Function
The X2000 is Dynavox's latest HiFi distributor, completing the X4100 and X7000 range. The X2000 takes up the basics again, this time with 5 Schuko sockets, an integrated phase detection system and a Master-Slave function. The latter will allow, if activated, to switch on all the devices connected to the ignition of one of them.
3.8 / 5
Reference : 14441
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 25-04-2025.
Dynavox X2000
Dynavox X2000 Distributeur Secteur Filtré 5 Prises Schuko Fonction Master-Slave
The X2000 is Dynavox's latest HiFi distributor, completing the X4100 and X7000 range. The X2000 takes up the basics again, this time with 5 Schuko sockets, an integrated phase detection system (only for IEC input cable) and a Master-Slave function. The latter will allow, if activated, to switch on all the devices connected to the ignition of one of them. The X2000's sockets are also filtered, allowing you to deliver an electrical signal specific to your devices. A 10A circuit breaker allows it to protect your system in case of over-current. All components are housed in a robust brushed aluminium case.
Product typePower strip
Sockets typeSchuko
Number of sockets5
Filtering
Phase detection function
Input connectorIEC C14 (power cable included)
Input voltage / current230V/50Hz 10A
Integrated circuit breaker10A
Output power2300W (230V)
Housing materialBrushed Aluminium
Dimensions100 x 90 x 470mm
Weight2.6kg
Package1x Dynavox X2000
1x Power cable 0.75mm² 1.5m
Number of sockets5
FilteringYes
5 reviews
avis positif mais un bémol
ce filtre apporte un gain indéniable en qualité de son, ce qui est le premier objectif...gain en aération globale et surtout incroyable gain de tension du grave (système en bi-amplification active)
par contra impossible de faire fonctionner le repérage de phase, l'indicateur de phase restant toujours allumé quelque soit la position de la prise....!
This review has been posted for DYNAVOX X2000 Filtered Power Strip 5 Schuko Sockets with Master-Slave Function
Consomme 20W en permanence
Oblige à éteindre manuellement la prise pour éviter une consommation électrique inutile, ce qui annule l'intérêt du dispositif maître/esclave.. Problème de conception ou de fabrication ? En tout cas ce n'est plus admissible sur aucun appareil électrique aujourd'hui, et encore moins sur un appareil haut de gamme. Retour à l'envoyeur.
Excellent Rapport Qualité Prix
Produit de conception solide, châssis robuste ce produit inspire confiance au touché. La fonction détection de phase est simplissime il suffit de brancher chacun de ces équipements un à un, la fonction prise Master permet aussi de mettre en veille un seul équipement et le reste Dac et Drive suivent. Enfin sur l’écoute cela reste subjectif, mais il y a un mieux prononcé sur l’ensemble du spectre notamment sur l’aiguë moins criard ainsi qu’une scène sonore mieux étagée. C’est un excellent investissement dans le cadre d’une optimisation de sa chaîne de valeur audio
Bon produit
Appareil d'apparence qualitative, tout est bien assemblé, fonctionnement correct, très pratique, semble costaud. Reste à l'éprouver dans le temps pour voir s'il est aussi fiable que son aspect respire la solidité.
Un peu decu
Alors je n ai même pas eu l envie de tester le produit au deballage
Le potentiomètre est pas centré mais en plus il penche d un côté
Le bouton en plasite du maître esclave frottre contre la paroit intérieur du trou du bloc d alu
Ces deux défauts ne m ont pas donné envie de la tester
Pour ceux qui sont pas trop exigent sur la qualité pourquoi pas mais quand on est exigent surtout dans cet ordre de prix passez votre chemin.
Je ne comprends pas comment des défauts aussi flagrant soit il, arrive à passer le contrôle qualité . Pour moi c est retour direct
Bonjour,
Les défauts que vous décrivez restent des défauts visuels mineurs. Le distributeur secteur et toutes ses fonctions fonctionne en somme parfaitement.
The X2000 is Dynavox's latest HiFi distributor, completing the X4100 and X7000 range. The X2000 takes up the basics again, this time with 5...
