DYNAVOX X7000 Power Filter 6 Schuko Sockets Silver
The Dynavox X7000, a direct evolution of the X6000, is a HiFi mains filter that provides your audio devices with a clean and stable power supply for quality sound reproduction. It filters out harmful interference from your power supply to cancel out residual noise.
Reference : 14488
175,00 €tax incl.
145,83 € tax excl.
Shipping date: 01-04-2025.
Dynavox X7000
Dynavox X7000 Filtre Secteur 6 Prises Schuko Argent
The Dynavox X7000, a direct evolution of the X6000, is a HiFi mains filter that provides your audio devices with a clean and stable power supply for quality sound reproduction. It filters out harmful interference from your power supply to cancel out residual noise. The X7000 is equipped with 4 filtered and 2 unfiltered Schuko plugs. Its front panel has a display indicating the input voltage or power consumption. This display can also be switched off if necessary and in order to limit light pollution. The X7000 also benefits from a memory allowing it to remember the last parameters used (voltage and ON/OFF display). Installation is very simple and all components are integrated in a robust aluminium housing. In addition, to protect your system, it includes a 10A circuit breaker as well as an LED that can indicate a phase inversion on the power supply line.
Product typePower strip
Main filter
Connectors4x Filtered female Schuko
2x Unfiltered female Schuko
Input voltage220-240V 50Hz
Circuit breaker10A
Output power2300W (230V)
Dimensions430 x 305 x 100mm
Housing materialAluminium
Weight6.15kg
ColorSilver
Number of sockets6
FilteringNo
The Dynavox X7000, a direct evolution of the X6000, is a HiFi mains filter that provides your audio devices with a clean and stable power supply...
