FURUTECH E-TP60E NCF Power Distributor 6 Sockets Rhodium Plated
Furutech's e-TP60E NCF is a high-end power distributor that eliminates many of the common problems encountered with audio and video equipment caused by widely contaminated power supplies.
By buying this product you get 128 loyalty points
Reference : 15886
649,00 €tax incl.
540,83 € tax excl.
Shipping date: 25-09-2026.
Furutech e-TP60E NCF
Furutech e-TP60E NCF Distributeur Secteur 6 Prises Plaqué Or
In a typical system, the AC waveform is distorted by ground noise, voltage spikes and drops, high-frequency power supply noise from other devices, and high-frequency digital noise from digital processors and connections. There is also distortion at the top and bottom of the AC waveform, created by the switching power supplies of electronic devices connected to the same circuit. In addition, in a residential home, electrical circuits are shared between units on the same transformer, generating interference.
The e-TP60E NCF power distributor steps in to provide your audio or video system with a clean power supply. Its beautiful aluminum chassis acts as a shield against RFI interference and a layer of FC-303 Formula blocks EMI interference. The high-quality Furutech internal cabling, with a cross-section of 2.08mm² (14AWG), ensures very low resistance and excellent electrical conductivity. The Schuko FI-E30 NCF connectors are wired to an IEC FI-06 NCF (R) header. All of the connectors in this power strip feature α (Alpha) marking for optimal conductivity and incorporate rhodium-plated pure copper contacts. The body of the connectors is made of nylon, fiberglass and NCF material offering excellent damping.
α (Alpha) Treatment
The connector contacts on this e-TP60E NCF power distributor feature the brand's α (Alpha) treatment. This consists of a two-step process to maximize conductor performance. The first step, cryogenics, brings the conductor material to a temperature between -196°C and -250°C. The treated elements then change their molecular structure, improving the electrical conductivity of the material. The second step consists in exposing these same elements to a very efficient demagnetization process, eliminating the magnetization of the material.
NCF
Incorporated in a selection of Furutech products, NCF (Nano Crystal² Formula) is a special crystalline material that has two "active" properties. It not only generates negative ions that eliminate static electricity, but also converts thermal energy into far infrared (LIR) with wavelengths ranging from 50µm to 5mm.
Furutech then combines this remarkable material with nanometric ceramic particles and carbon powder for their piezoelectric effect (damping property). The result is NCF, the ultimate electrical and mechanical damping material.
Formula GC-303
The GC-303 is a special material integrated on the inside bottom plate of the chassis, absorbing any EMI noise that may be transmitted by a power supply or generated by other equipment.
Product typePower distributor
Input1x IEC C14 FI-06 NCF (R)
Outputs6x Schuko FI-E30 NCF
Rated voltage250VAC 50/60Hz
Rated current10A
Power handling2500W
Contacts materialα (Alpha) treatred copper
Contacts platingRhodium
Connectors bodyNylon
Fiberglass
NCF
Wiring section2.08mm² (14AWG)
Number of sockets6
FilteringNo
Furutech's e-TP60E NCF is a high-end power distributor that eliminates many of the common problems encountered with audio and video equipment...
