FURUTECH E-TP86E (G) Power Distributor 8 Sockets Gold Plated
Furutech's e-TP86E (G) is a high-end power distributor that eliminates many of the common problems encountered with audio and video equipment caused by widely contaminated power supplies.
By buying this product you get 171 loyalty points
Reference : 17578
575,00 €tax incl.
479,17 € tax excl.
Shipping date: 25-04-2025.
Furutech e-TP86E (G)
In a typical system, the AC waveform is distorted by ground noise, voltage spikes and drops, high-frequency power supply noise from other devices, and high-frequency digital noise from digital processors and connections. There is also distortion at the top and bottom of the AC waveform, created by the switching power supplies of electronic devices connected to the same circuit. In addition, in a residential home, electrical circuits are shared between units on the same transformer, generating interference.
The e-TP86E (G) power distributor steps in to provide your audio or video system with a clean power supply. Its beautiful aluminum chassis acts as a shield against RFI interference. The high-quality Furutech internal cabling, with a cross-section of 2mm² (14AWG), ensures very low resistance and excellent electrical conductivity. The Schuko FI-E30 (G) 16A connectors are wired to an IEC FI-06 (G) header. All of the connectors in this power strip incorporate gold-plated copper alloy contacts.
Product typePower distributor
Input1x IEC C14 FI-06 (G)
Outputs8x Schuko FI-E30 (G)
Rated voltage250VAC 50/60Hz
Rated current10A
Power handling2500W
Contacts materialCopper Alloy
Contacts platingGold
Wiring section2mm² (14AWG)
Number of sockets8
FilteringNo
Furutech's e-TP86E (G) is a high-end power distributor that eliminates many of the common problems encountered with audio and video equipment...
