FURUTECH FT-SWS-D NCF BOX Power Distributor 2 Sockets Rhodium Plated Copper NCF
The Furutech FT-SWS-D NCF Box is a dual power distributor with high-end Schuko connectors. Its high quality design allows it to provide a non-degraded AC electrical signal that greatly contributes to the audio quality of your system.
By buying this product you get 122 loyalty points
Reference : 16341
612,00 €tax incl.
510,00 € tax excl.
Furutech FT-SWS-D NCF Box Distributeur Secteur 2 Prises Cuivre Plaqué Rhodium NCF
The contacts of these sockets are made of pure copper with rhodium plating, ensuring excellent signal conductivity. Moreover, these contacts are treated with Alpha (α), a cryogenic process that eliminates impurities to the maximum and promotes conductivity. The front panel of the mains distributor has a beautiful carbon and fiberglass coating.
xxx
Nano Crystal² Formula (NCF)
Integrated in a selection of Furutech products, NCF is based on a special crystalline material with two active properties. First, NCF generates negative ions that eliminate static electricity. Secondly, it converts thermal energy into infrared. Furutech combines this material with Ceramic nano particles and Carbon powder for their piezoelectric damping properties. Furutech thus obtains the optimal electrical and mechanical damping material.
Product typePower distributor
Input connector1x IEC C14 Furutech FI-06 NCF
Output connectors2x NCF Rhodium Plated Female Schuko
Voltage / Current250VAC 10A
Treatment of metal partsα (Alpha)
Internal wiringα (Alpha) treated OCC Copper 2mm²
Dimensions164 x 108.5 x 71mm
Number of sockets2
FilteringNo
The Furutech FT-SWS-D NCF Box is a dual power distributor with high-end Schuko connectors. Its high quality design allows it to provide a...
