LUDIC HEIMDALL Filtered Power Distributor 8 Sockets Aluminum Silver
The Ludic Heimdall filtered power distributor effectively eliminates any unwanted interference from the power grid or other connected devices. It thus allows your devices to deliver their full potential for high quality listening.
Reference : 15387
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 22-04-2025.
Ludic Heimdall
Ludic Heimdall Distributeur Secteur Filtré 8 Prises Schuko Aluminium Noir
The components of this power distributor are concealed under a solid brushed aluminum frame with a damped subframe to reduce mechanical vibrations. The power strip consists of 8 high-quality Schuko sockets. The input is made on an IEC C14 connector and will allow you to use a high-performance cable instead of the supplied one.
The power distributor also includes surge protection to effectively protect your devices. A vumeter on the front panel indicates the operating status of the power strip and an LED illuminates red, indicating the need to control the grounding. Two pushbuttons allow them to turn on or off the two power supply rails independently.
The vumeter only lights up when the "2" button is pressed and line 2 is powered.
Product typeFiltered power distributor
Input voltage220V AC, 50/60Hz
Input1x IEC C14
Outputs8x Female Schuko
Max power3000W
Max load15A
Surge protection
Housing materialBrusshed aluminum
ColorSilver
Dimensions31 x 13 x 11cm
Package1x Ludic Heimdall
1x Power cable
Number of sockets8
FilteringYes
The Ludic Heimdall filtered power distributor effectively eliminates any unwanted interference from the power grid or other connected devices. It...
