LUDIC KRATOS Filtered Power Distributor Black
The Ludic Kratos is an extremely powerful filtered section power distributor, capable of standing comparison with the highest quality products. It provides your HiFi equipment with a clean and stable power supply. The resulting sound is more punchy with a wider and deeper soundstage and noise reduction to reveal the smallest details of your music
By buying this product you get 34 loyalty points
Reference : 19963
349,00 €tax incl.
290,83 € tax excl.
Shipping date: 25-04-2025.
Ludic Kratos Filtered Power Distributor 8 Filter Outlets Schuko Black
Ludic Kratos : Front view
The Ludic Kratos is an extremely powerful filtered section power distributor, capable of standing comparison with the highest quality products. It provides your HiFi equipment with a clean and stable power supply. The resulting sound is more punchy with a wider and deeper soundstage and noise reduction to reveal the smallest details of your music.
The Ludic Kratos components are housed in a robust brushed aluminum case with a damped secondary chassis that reduces mechanical vibrations of the filter components caused by the 50Hz grid frequency. With a thickness of 7mm, it also limits the impact of interference on the electrical signal. The integrated surge suppressor protects your devices from voltage spikes.
The Ludic Kratos also features a beautiful LED display on the front panel, indicating in real time the operating status of the power distributor.
Ludic Kratos : Schematic view of the facade
  • P (Power) : Indicates the total power used
  • I (Current) : Indique le courant total utilisé sur l'ensemble du circuit.
  • U (Voltage) : Indicates the voltage of the circuit.
  • Load / Rate : Indicates the percentage of power used compared to the maximum available.
Ludic Kratos : Schematic view of Schuko sockets
The Ludic Kratos uses European Schuko type plugs made of glass fiber reinforced ABS plastic, offering a very good resistance to high temperatures.
The power distributor has eight filtered outlets. It also has overload protection with a button on the back of the chassis.
Product typePower distributor
Socket typeSchuko
Number of sockets8x Filtered sockets
Housing materialBrushed aluminum
Package1x Ludic Kratos
Number of sockets8
FilteringYes
LUDIC KRATOS Filtered Power Distributor 8 Filter Outlets Schuko Black
The Ludic Kratos is an extremely powerful filtered section power distributor, capable of standing comparison with the highest quality products. It...
