LUDIC KRATOS Filtered Power Distributor 6 Filter Outlets + 2 Direct Outlets Schuko Black
The Ludic Kratos is an extremely powerful filtered section power distributor, capable of standing comparison with the highest quality products. It provides your HiFi equipment with a clean and stable power supply. The resulting sound is more punchy with a wider and deeper soundstage and noise reduction to reveal the smallest details of your music.
By buying this product you get 34 loyalty points
Reference : 16590
349,00 €tax incl.
290,83 € tax excl.
Shipping date: 25-04-2025.
Ludic Kratos
Filtered Power Distributor 6 Filter Outlets + 2 Direct Schuko Sockets Black
Ludic Kratos Distributeur Secteur Filtre 8 Prises Schuko Noir
The Ludic Kratos components are housed in a robust brushed aluminum case with a damped secondary chassis that reduces mechanical vibrations of the filter components caused by the 50Hz grid frequency. With a thickness of 7mm, it also limits the impact of interference on the electrical signal. The integrated surge suppressor protects your devices from voltage spikes.
The Ludic Kratos also features a beautiful LED display on the front panel, indicating in real time the operating status of the power distributor.
P (Power) : Indicates the total power used.
I (Current) : Indique le courant total utilisé sur l'ensemble du circuit.
U (Voltage) : Indicates the voltage of the circuit.
Load / Rate : Indicates the percentage of power used compared to the maximum available.
The Ludic Kratos uses European Schuko type plugs made of glass fiber reinforced ABS plastic, offering a very good resistance to high temperatures.
The power distributor has two direct and six filtered outlets. It also has overload protection with a button on the back of the chassis.
Product typePower distributor
Socket typeSchuko
Number of sockets2x Direct sockets
6x Filtered sockets
Housing materialBrushed aluminum
Number of sockets8
FilteringYes
3 reviews
parfait
trés bon rapport qualité/prix
patience récompensée
This review has been posted for LUDIC KRATOS Filtered Power Distributor 6 Filter Outlets + 2 Direct Outlets Schuko Black
Bel objet
Je ne saurais pas dire si le filtrage est efficace, je n'ai pas l'équipement et les connaissances précises en la matière pour le faire.
Mais la fabrication est de qualité. Et l'écran, et c'est rare pour ce genre d'objet, ne fait pas kitch. C'est sérieux et classe.
 (3)
Ludic Kratos Recommened Product
For device I will give five stars and for the Ludic support I will rather give two stars but fortunately we have Audiophonics.
I can compare this product with products up to 500 euros and it is noticable upgrade in my case. The device removed that grainy overlay from the music in my system. So yes, there is less noise and you get that feeling of better dynamics and better instrument separation.
Pros: Very good filtering, quality build, 6+2 sockets, fancy display with useful info.
Cons: brass contacts in sockets.
Technical specs:
Dimensions WxHxD 15x10x29,5 cm
Weight 2745 g
Number of sockets 8 (filered 6, unfiltered 2)
Maximum load up to 3000W.
Maximum current up to 15A (fused).
Wiring is parallel connection lines. Socket contacts are brass, internal wires are OFC. Wire skin is PVC.
 (6)
The Ludic Kratos is an extremely powerful filtered section power distributor, capable of standing comparison with the highest quality products. It...
