OYAIDE MTS-6e Power Distributor 6 Plugs Schuko OFC Schuko Gold / Palladium Plated
The Oyaide MTS-6e is a power distributor with 6 Schuko plugs. It features a beautiful design, promoting excellent conductivity to deliver a clean electrical signal to your HiFi equipment. The integrated SWD-XXX plugs use a double spring system to provide a strong holding power with a large 9mm contact area for perfect transmission and true vibration limitation.
By buying this product you get 109 loyalty points
Reference : 15451
1 099,00 €tax incl.
915,83 € tax excl.
Oyaide MTS-6e
Oyaide MTS-6e Distributeur Secteur 6 Prises Schuko Cuivre OFC Plaqué Or / Palladium
The sockets are mounted in a highly rigid, non-magnetic SUS 304 stainless steel frame. It protects not only from vibrations but also from electromagnetic waves and external interference. In addition, all components of this power strip, right down to the screws, use non-magnetic materials.
SS-47 solder was used to assemble the MTS-6e. It contains pure 4N tin (99.993% purity) obtained by removing impurities to the maximum. In addition, 4.7% silver and 1.7% copper are contained in order to improve the electrical conductivity and durability of the power distributor.
The IEC C14 input connector, specially designed for the MT range, uses brass contacts with 1.5µ Silver and 0.3µ Rhodium plating. The body is made of PBT 30%GF. Inside the chassis, a sheet of VEM313 (Visco Elastic Material) provides effective damping.
The internal wiring uses 2mm OFC 4N copper wire. The cable insulation is made of a low dielectric polyolefin resin.
Finally, for a better separation between the mains distributor and its support, brass pins have been specially machined with precision. Although the MTS-6e comes standard with a 4-point bracket, it can also be used with a 3-point bracket.
Product typePower distributor
Outputs6x Schuko
Input1x IEC C14
Schuko contacts platingGold 24k + Palladium
Wiring conductorsOFC Copper 4N 2mm
HousingStainless steel 1.6mm
Rated Voltage / Current250V 10A AC
Dimensions460 x 75 x 53mm
ColorSilver
Weight2.7kg
Number of sockets6
FilteringNo
The Oyaide MTS-6e is a power distributor with 6 Schuko plugs. It features a beautiful design, promoting excellent conductivity to deliver a clean...
