By buying this product you get 184 loyalty points
The Oyaide MTS-6e-SSE is a power distributor with 6 Schuko plugs. It features a beautiful design, promoting excellent conductivity to deliver a clean electrical signal to your HiFi equipment. The integrated SWD-XXX plugs use a double spring system to provide a strong holding power with a large 9mm contact area for perfect transmission and true vibration limitation.
The sockets are mounted in a highly rigid, non-magnetic SUS 304 stainless steel frame. It protects not only from vibrations but also from electromagnetic waves and external interference. In addition, all components of this power strip, right down to the screws, use non-magnetic materials.
SS-47 solder was used to assemble the MTS-6e-SSE. It contains pure 4N tin (99.993% purity) obtained by removing impurities to the maximum. In addition, 4.7% silver and 1.7% copper are contained in order to improve the electrical conductivity and durability of the power distributor.
The IEC C14 input connector, specially designed for the MT range, uses brass contacts with 1.5µ Silver and 0.3µ Rhodium plating. The body is made of PBT 30%GF. Inside the chassis, a sheet of VEM313 (Visco Elastic Material) provides effective damping.
The internal wiring uses 2mm 4N pure silver wire. The cable insulation is made of a low dielectric polyolefin resin.
Finally, for a better separation between the mains distributor and its support, brass spikes have been specially machined with precision. Although the MTS-6e-SSE comes standard with a 4-point bracket, it can also be used with a 3-point bracket.
Product type | Power distributor |
Outputs | 6x Schuko |
Input | 1x IEC C14 |
Schuko contacts plating | Gold 24k + Palladium |
Wiring conductors | Pure silver 4N 2mm |
Housing | Stainless steel 1.6mm |
Rated Voltage / Current | 250V 10A AC |
Dimensions | 460 x 75 x 53mm |
Color | Silver |
Weight | 2.7kg |
