MUNDORF E-CAP ECAP100 (BR100) RAW Capacitor 100VDC 32VAC 10μF
Mundorf E-Cap ECAP100 (BR100) RAW 10µf
Mundorf E-Cap audio and signal coupling capacitors are bipolar electrolytic capacitors. They are used in applications where film capacitors are not suitable for space or cost reasons, as they are generally much more compact than their film counterparts. In particular, they are widely used in crossover filters.
Reference : 4263
1,80 €tax incl.
1,50 € tax excl.
Shipping date: 16-07-2024.
Capacitor 100VDC 32VAC 10µF
Mundorf E-Cap ECAP100 (BR100) RAW Condensateur 100VDC 32VAC 10µF
There are two ranges of E-Cap capacitors. The RAW range consists of the ECAP100 and ECAP63 models (BR100 and BR63). Capacitors in this range are made of foils whose surface is roughened by a special etching process that enlarges their surface. As the capacitance is proportional to the surface area, this process results in compact and inexpensive capacitors.
These capacitors are bipolar and have a second aluminium foil for resistance to AC voltage, making them suitable for AC audio signals.
Product typeCapacitor
Capacity10µF
Voltage100VDC
32VAC
Tolerance±5
DielectricPolypropylene (PP)
Loss factortan ∂ 0.050 @ 1kHz
Service life3000h @ +85°C
Temperature range-40°C to 85°C
DimensionsØ10 x 30mm
Wires diameter0.8mm
Wires length40mm
Tolerance (%)5.0
Capacitor capacitance10
Rated voltage (V)100.0
Rated voltage (V)32.0
Capacitor typeElectrolytic capacitor
Capacitor formatAxial
3 reviews
Excellent !
Voilà une série de condensateurs d'excellente qualité audio, très belle fabrication compacte.
Je les ai monté en parallèle dans mes filtres d'enceintes et aucune différence avec des condensateurs MKP de haut vol dans cette configuration.
Toujours aussi rapide Audiophonics pour la livraison, en 24h, bravo !! bravo vraiment !!
This review has been posted for MUNDORF E-CAP ECAP100 (BR100) RAW Capacitor 100VDC 32VAC 10μF
Ils sont extras.
Très belle fabrication pour filtres en parallèle d'enceintes. Livraison 24h !
Très bien
Filtre très bien sur mon haut parleur full range, plus aucune bass sur celui-ci
Mundorf E-Cap audio and signal coupling capacitors are bipolar electrolytic capacitors. They are used in applications where film capacitors are not...
