MUNDORF E-CAP ECAP70 (BG50) PLAIN Capacitor 70VDC 50VAC 1µF
Mundorf E-Cap audio and signal coupling capacitors are bipolar electrolytic capacitors. They are used in applications where film capacitors are not suitable for space or cost reasons, as they are generally much more compact than their film counterparts. In particular, they are widely used in crossover filters.
Reference : 4272
1,50 €tax incl.
1,25 € tax excl.
Mundorf E-Cap ECAP70 (BG50) PLAIN
Mundorf E-Cap ECAP70 (BG50) PLAIN Condensateur 70VDC 50VAC
There are two ranges of E-Cap capacitors. The PLAIN range consists of the ECAP70 (BG50) and ECAP50 models. Capacitors in this range are made of smooth foils and therefore allow low losses for better sound quality.
These capacitors are bipolar and have a second aluminium foil for resistance to AC voltage, making them suitable for AC audio signals.
Product typeCapacitor
Capacity1µF
Voltage70VDC
50VAC
Tolerance±5
DielectricPolypropylene (PP)
Loss factortan ∂ 0.025 @ 1kHz
Service life5000h @ +85°C
Temperature range-40°C to 85°C
DimensionsØ10 x 20mm
Wires diameter0.8mm
Wires length40mm
Tolerance (%)5
Capacitor capacitance (µF)1
Rated voltage (V)70.0
Capacitor typeElectrolytic capacitor
Capacitor formatAxial
Modification filtrage HP Klipsch RF83
Après l'achat de paires d'enceintes Klipsch RF83 je me suis rapidement rendu compte que le son sortant du pavillon était comme a gressif (haut medium) et étouffé, j'ai donc pris l’initiative de bypasser la partie du filtrage aiguës , et après plusieurs test avec des valeurs différentes 2,2/1,5/1uf c'est ce petit dernier qui m'apporte enfin les aiguës dont je rêvais, fini pour moi l'agressivité et l'étouffement du pavillon du à l'étrange manière dont Klipsch a voulu bridé celui. Merci audiophonics ;-)
This review has been posted for MUNDORF E-CAP ECAP70 (BG50) PLAIN Capacitor 70VDC 50VAC 1µF
Mundorf E-Cap audio and signal coupling capacitors are bipolar electrolytic capacitors. They are used in applications where film capacitors are not...
