MUNDORF E-CAP ECAP100 (BR100) RAW Capacitor 100VDC 32VAC 56μF
Mundorf E-Cap audio and signal coupling capacitors are bipolar electrolytic capacitors. They are used in applications where film capacitors are not suitable for space or cost reasons, as they are generally much more compact than their film counterparts. In particular, they are widely used in crossover filters.
Reference : 4268
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 22-04-2025.
Mundorf E-Cap ECAP100 (BR100) RAW
Capacitor 100VDC 32VAC 56µF
Mundorf E-Cap ECAP100 (BR100) RAW Condensateur 100VDC 32VAC 10µF
There are two ranges of E-Cap capacitors. The RAW range consists of the ECAP100 and ECAP63 models (BR100 and BR63). Capacitors in this range are made of foils whose surface is roughened by a special etching process that enlarges their surface. As the capacitance is proportional to the surface area, this process results in compact and inexpensive capacitors.
These capacitors are bipolar and have a second aluminium foil for resistance to AC voltage, making them suitable for AC audio signals.
Product typeCapacitor
Capacity56µF
Voltage100VDC
32VAC
Tolerance±5
DielectricPolypropylene (PP)
Loss factortan ∂ 0.050 @ 1kHz
Service life3000h @ +85°C
Temperature range-40°C to 85°C
DimensionsØ14 x 37mm
Wires diameter0.8mm
Wires length40mm
Tolerance (%)
  • 5
Capacitor capacitance (µF)
  • 56
Rated voltage (V)
  • 100
  • 32.0
Capacitor type
  • Electrolytic capacitor
Capacitor format
  • Axial
Mundorf E-Cap audio and signal coupling capacitors are bipolar electrolytic capacitors. They are used in applications where film capacitors are not...
