MUNDORF MCAP EVO OIL Capacitor 350V 56µF
Reference : 11439
69,90 €tax incl.
58,25 € tax excl.
Condensateur MUNDORF MCAP EVO OIL Condensateur 350V 56µF
Mundorf MCAP EVO Oil
The EVO series at Mundorf is intended to offer very high audio precision at a low price and with minimal space-use
Its polypropylene film (PP) is metallized with a layer of aluminum as thick as possible and with a proprietary geometry (Evolution Winding). The coil is then hand-mounted in a shell designed to reduce vibrations.
All these features contribute to a very lively audio reproduction that deeply respects microdynamics and stereophony. The whole EVO series is compliant to the highest standards of safety (self-healing).
Rigid wires for connections are long enough to allow vertical or horizontal mounting. Note that the shorter tab indicates the outer sheet of the capacitor.
This model belongs to the EVO Oil range introducing an oil impregnation step of the polypropylene (PP) films before building the coil. This maneuver removes residual air bubbles with formidable efficiency, which drastically reduces the electrical and mechanical losses associated with vibrations.
Dimensions
Capacitor Mcap EVO
TypeCapacitor Mcap EVO
Capacitance56 µF
Voltage350V
Tolerance±3%
Diameter65
Lengthr50
Connct wire diameter1,4
Connect wire length (A)50
Connect wire length (B)105
Maximum room temp85°C
DielectricPolypropylene (PP)
MetallisationAluminum
Dielectric loss0.0002@1kHz · 0.0001@10kHz
Tolerance (%)3
Capacitor capacitance (µF)56
Rated voltage (V)350.0
Capacitor typeFilm capacitor
Capacitor formatAxial
Parfaite dans le signal du Médium.
Dans le filtre du Médium sur une 3 voies, la capa dans le signal a une valeur importante. Si on veut garder de la qualité sans trop casser son budget, cette gamme EVO Oil est parfaite.Et toujours la livraison en quelques jours d'audiophonics. C'est une de ces grandes forces. Il a compris que les gens qui bricolent sont impatient. Bravo.
This review has been posted for MUNDORF MCAP EVO OIL Capacitor 350V 56µF
