MUNDORF MCAP EVO OIL Capacitor 450V 10μF
Reference : 7300
25,90 €tax incl.
21,58 € tax excl.
Shipping date: 07-07-2026.
Condensateur MUNDORF MCAP EVO OIL Condensateur 450V 10µF
Mundorf MCAP EVO Oil
The EVO series at Mundorf is intended to offer very high audio precision at a low price and with minimal space-use
Its polypropylene film (PP) is metallized with a layer of aluminum as thick as possible and with a proprietary geometry (Evolution Winding). The coil is then hand-mounted in a shell designed to reduce vibrations.
All these features contribute to a very lively audio reproduction that deeply respects microdynamics and stereophony. The whole EVO series is compliant to the highest standards of safety (self-healing).
Rigid wires for connections are long enough to allow vertical or horizontal mounting. Note that the shorter tab indicates the outer sheet of the capacitor.
This model belongs to the EVO Oil range introducing an oil impregnation step of the polypropylene (PP) films before building the coil. This maneuver removes residual air bubbles with formidable efficiency, which drastically reduces the electrical and mechanical losses associated with vibrations.
Dimensions
Capacitor Mcap EVO
TypeCapacitor Mcap EVO
Capacitance10 µF
Voltage450V
Tolerance±3%
Diameter75
Lengthr50
Connct wire diameter1,4
Connect wire length (A)50
Connect wire length (B)105
Maximum room temp85°C
DielectricPolypropylene (PP)
MetallisationAluminum
Dielectric loss0.0002@1kHz · 0.0001@10kHz
Tolerance (%)3
Capacitor capacitance (µF)10
Rated voltage (V)450.0
Capacitor typeFilm capacitor
Capacitor formatAxial
Parfait
Condensateur utilisé avec un bypass de 0.01 uf pour refaire un filtre passif (Medium/Grave) qui donne entière satisfaction. Je l'ai utilisé en combo avec un Jantzen Superior z-cap qui se marie très bien pour la dynamique qu'apporte l'evo oil Mundorf. En plus il est peu encombrant. C'est du solide. Audiophonics, vous vous êtes trompés sur les dimensions de ce produit.
This review has been posted for MUNDORF MCAP EVO OIL Capacitor 450V 10μF
