MUNDORF MCAP EVO OIL Capacitor 650V 0.1μF
Reference : 7283
13,90 €tax incl.
11,58 € tax excl.
Shipping date: 29-04-2025.
Condensateur MUNDORF MCAP EVO OIL Condensateur 650V 0.1µF
Mundorf MCAP EVO Oil
The EVO series at Mundorf is intended to offer very high audio precision at a low price and with minimal space-use
Its polypropylene film (PP) is metallized with a layer of aluminum as thick as possible and with a proprietary geometry (Evolution Winding). The coil is then hand-mounted in a shell designed to reduce vibrations.
All these features contribute to a very lively audio reproduction that deeply respects microdynamics and stereophony. The whole EVO series is compliant to the highest standards of safety (self-healing).
Rigid wires for connections are long enough to allow vertical or horizontal mounting. Note that the shorter tab indicates the outer sheet of the capacitor.
This model belongs to the EVO Oil range introducing an oil impregnation step of the polypropylene (PP) films before building the coil. This maneuver removes residual air bubbles with formidable efficiency, which drastically reduces the electrical and mechanical losses associated with vibrations.
Dimensions
Capacitor Mcap EVO
TypeCapacitor Mcap EVO
Capacitance0,10 µF
Voltage650V
Tolerance±5%
Diameter18
Lengthr12
Connct wire diameter0,6
Connect wire length (A)35
Connect wire length (B)35
Maximum room temp85°C
DielectricPolypropylene (PP)
MetallisationAluminum
Dielectric loss0.0002@1kHz · 0.0001@10kHz
Tolerance (%)5
Capacitor capacitance (µF)0.1
Rated voltage (V)650.0
Capacitor typeFilm capacitor
Capacitor formatAxial
Bon condensateur MKP pour la liaison inter-étage d'appareils à tubes.
Alalternative économique aux papiers huilés...
This review has been posted for MUNDORF MCAP EVO OIL Capacitor 650V 0.1μF
