MUNDORF MCAP EVO SILVERGOLD OIL Capacitor 450V 4.7μF
Reference : 7663
56,90 €tax incl.
47,42 € tax excl.
Shipping date: 29-04-2025.
Mundorf MCAP EVO SilverGold Oil
EVO Mcap by Mundorf is designed to ofeer tremendous audio precision at affordable price with low space-consumption. It fills every condition to offer a great sound restitution with rich and deep audio details.
Its polypropylene film (PP) is metallized with a layer of aluminum as thick as possible and formed following a proprietary geometry (Evolution Winding). The coil is then hand-poted in a audio shell order to reduce vibrations.
All these features contribute to a very lively audio reproduction that deeply respects microdynamics and stereophony. The whole EVO series is compliant to the highest standards of safety (self-healing).
Rigid wires for connections are made from gold-plated copper. They are long enough to allow vertical or horizontal mounting. Note that the shorter tab indicates the outer sheet of the capacitor.
This model belongs to the EVO Oil range introducing an oil impregnation step of the polypropylene (PP) films before building the coil. This maneuver removes residual air bubbles with formidable efficiency, which drastically reduces the electrical and mechanical losses associated with vibrations.
Dimensions
Condensateur Mcap EVO
TypeMcap EVO Silver Oil Capacitor
Capacity4.7 µF
Voltage450V
Tolerance±3%
Diameter30 mm
Length27
Wire diameter1,0
Wire A length35
Wire B length60
Temperature max-25°C / +125°C
DielectricPolypropylene (PP)
MetallisationAluminim
Dielectric loss0.0002@1kHz · 0.0001@10kHz
Tolerance (%)3
Capacitor capacitance (µF)4.7
Rated voltage (V)450.0
Capacitor typeFilm capacitor
Capacitor formatAxial
La Rolls Royce des condos
Ces condos distillent la moindre info qui passe dedans et la sublime. S'est duveteux , les voix sont sublimées, la texture des cymbales est incroyablement retranscrite. Je recommande fortement pour accompagné dans un montage tubes et ils valent leurs prix. Grand merci à Audiophonics de commercialiser de telle condos.
This review has been posted for MUNDORF MCAP EVO SILVERGOLD OIL Capacitor 450V 4.7μF
