MUNDORF MCAP EVO Capacitor 450V 2.7μF
Reference : 6877
13,90 €tax incl.
11,58 € tax excl.
Shipping date: 11-09-2026.
Condensateur Mundorf Mcap EVO
Mundorf Mcap EVO
Mundorf's Mcap EVO capacitors have gone through a high precision winding process before being hand-mounted in a shell layer specifically designed to reduce vibration and microphonics.
The particular shape of these capacitors as well as their robust construction allows for horizontal or vertical mounting without affecting performance or durability.
The inner coil has a narrow and tall profile. An unusual feature that results in a better ESR (equivalent resistance) and a reduced ESL (equivalent inductance). Indeed, a long and tight coil facilitates the signal path while increasing the number of windings traveled: redoubled efficiency and controlled size.
Dimensions
Capacitor Mcap EVO
TypeCapacitor Mcap EVO
Capacitance2,70 µF
Voltage450V
Tolerance±3%
Diameter30
Lengthr21
Connct wire diameter0,8
Connect wire length (A)35
Connect wire length (B)50
Maximum room temp85°C
DielectricPolypropylene (PP)
MetallisationAluminum
Dielectric loss0.0002@1kHz · 0.0001@10kHz
Tolerance (%)3
Capacitor capacitance (µF)2.7
Rated voltage (V)450.0
Capacitor typeFilm capacitor
Capacitor formatAxial
Excellent rapport qualité Prix
Pour les filtres d'enceintes, si on cherche un coup très bas sans trop sacrifier le signal.
Sinon, je les utilise dans tous mes filtres pour les circuits de compensation, et réserve des "Suprèmes" sur le trajet direct du signal.
This review has been posted for MUNDORF MCAP EVO Capacitor 450V 2.7μF
