MUNDORF MCAP SUPREME Capacitor 1400V 0.1μF
Reference : 993
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 29-04-2025.
The Mcap Supreme is an internationally recognized ultimate capacitor.Its remarkable sound qualities are obtained through a combination of advanced techniques:- A winding technology without inductance : Two coils are interlaced in the capacitor, so that the inductors are eliminated reciprocally. These two coils are connected in series. This means that for the production of a 1μF Mcap Supreme capacitor, two 2μF coils are used, which would give 4μF for a conventional capacitor.
- Use of the best materials : the polypropylene sheet used for Mcap Supreme is characterized by a minimal loss.
- Robust plastic and aluminum housings : This prevents micro feedback and retains important signal details
The results of listening justify all the effort that we put in the MCap SUPREME.
No capacitor gives as much spacialization and perfect reproduction of the finest musical nuances. You can use MCap SUPREME in any audio application that requires high-precision filtering, the result
will always be surprising and convincing. Expect a new dimension of musical reproduction. This effect is also remarkable with modest speakers!
For a great audiophile experience, try this capacitor!
DielectricPolypropylene
Tolerance±2%
Dielectric lossTan = 0.00002 à 1kHz&' 0.00001 at 10kHz
Capacity0,1µF
Voltage1400VDC
Body Diameter17 mm
Body Length36mm
Wiring Diameter0,8 mm
Wiring length60mm
Tolerance (%)2
Capacitor capacitance (µF)0.1
Rated voltage (V)1400.0
Capacitor typeFilm capacitor
Capacitor formatAxial
2 reviews
High quality capacitors!!!
Best capacitors money can buy!!! High quality, natural, dynamic and detailed!!!
This review has been posted for MUNDORF MCAP SUPREME Capacitor 1400V 0.1μF
Mundorf Mcap Supreme
Remplacement des 4 condensateurs de liaison dans un ampli à tubes Cayin A88T par des Mundorf Mcap Supreme . Résultat étonnant , j'ai la sensation d'avoir changé d'ampli: plus d'espace et de profondeur , aigu plus soyeux.découverte de micro-informations inconnues jusqu'alors.A conseiller vivement.
