MUNDORF MCAP SUPREME Capacitor 600V 10μF
Reference : 1012
47,90 €tax incl.
39,92 € tax excl.
The Mcap Supreme is an internationally recognized ultimate capacitor.Its remarkable sound qualities are obtained through a combination of advanced techniques:- A winding technology without inductance : Two coils are interlaced in the capacitor, so that the inductors are eliminated reciprocally. These two coils are connected in series. This means that for the production of a 1μF Mcap Supreme capacitor, two 2μF coils are used, which would give 4μF for a conventional capacitor.
- Use of the best materials : the polypropylene sheet used for Mcap Supreme is characterized by a minimal loss.
- Robust plastic and aluminum housings : This prevents micro feedback and retains important signal details
The results of listening justify all the effort that we put in the MCap SUPREME.
No capacitor gives as much spacialization and perfect reproduction of the finest musical nuances. You can use MCap SUPREME in any audio application that requires high-precision filtering, the result
will always be surprising and convincing. Expect a new dimension of musical reproduction. This effect is also remarkable with modest speakers!
For a great audiophile experience, try this capacitor!
DielectricPolypropylene
Tolerance±2%
Dielectric lossTan = 0.00002 à 1kHz & 0.00001 at 10kHz
Capacity10µF
Voltage600VDC
Body Diameter36 mm
Body Length106mm
Wiring Diameter1,4 mm
Wiring length60mm
Tolerance (%)2
Capacitor capacitance (µF)10
Rated voltage (V)600.0
Capacitor typeFilm capacitor
Capacitor formatAxial
2 reviews
Ottim condensatore
Personalmente l'ho usato in un medio non diretto al segnale, ma fa il suo lavoro egragiamente, ottimo rapporto prezzo qualità, come sempre Mundorf conferma che alla salita del prezzo ci siano pi aspettative. Sopra la media in raporto qualità prezzo rispetto altre marche. Pulito, trasparente come ci si aspetta.
This review has been posted for MUNDORF MCAP SUPREME Capacitor 600V 10μF
Super qualité
Cette gamme de condensateurs d'excellente réputation est idéal en liaison / filtrage
Le 10uf est un beau bestiau
106mm x 36 de diamètre...
Le tout encapsulé dans un cylindre d' aluminium.
Rien à redire
