MUNDORF MCAP SUPREME Capacitor 600V 3.3μF
Reference : 1006
28,90 €tax incl.
24,08 € tax excl.
Shipping date: 29-04-2025.
The Mcap Supreme is an internationally recognized ultimate capacitor.Its remarkable sound qualities are obtained through a combination of advanced techniques:- A winding technology without inductance : Two coils are interlaced in the capacitor, so that the inductors are eliminated reciprocally. These two coils are connected in series. This means that for the production of a 1μF Mcap Supreme capacitor, two 2μF coils are used, which would give 4μF for a conventional capacitor.
- Use of the best materials : the polypropylene sheet used for Mcap Supreme is characterized by a minimal loss.
- Robust plastic and aluminum housings : This prevents micro feedback and retains important signal details
The results of listening justify all the effort that we put in the MCap SUPREME.
No capacitor gives as much spacialization and perfect reproduction of the finest musical nuances. You can use MCap SUPREME in any audio application that requires high-precision filtering, the result
will always be surprising and convincing. Expect a new dimension of musical reproduction. This effect is also remarkable with modest speakers!
For a great audiophile experience, try this capacitor!
DielectricPolypropylene
Tolerance±2%
Dielectric lossTan = 0.00002 à 1kHz & 0.00001 at 10kHz
Capacity3,3µF
Voltage600VDC
Body Diameter30 mm
Body Length56mm
Wiring Diameter1,4 mm
Wiring length60mm
Tolerance (%)2
Capacitor capacitance (µF)3.3
Rated voltage (V)600.0
Capacitor typeFilm capacitor
Capacitor formatAxial
2 reviews
Mise à niveau réellement audible
En remplacement d’un MCap standard dans le filtre d’une paire de JERN AUDIO 11s, l’opération n’est pas si simple, la taille du Suprême est 4 fois plus importante !
Mais l’entreprise et le temps passé en valent le coup.
Tout est bien plus homogène, certaine crispation des aiguës ont disparue ( câbles Nordost sans pitié ).
L’investissement financier est fondé.
Ravi de ce produit.
This review has been posted for MUNDORF MCAP SUPREME Capacitor 600V 3.3μF
Excellent condo pour filtrer les tweeter. L effort du prix est a la hauteur de la recompense.
