Used these as input signal capacitors in my 5881 power amps. Very clear detailed sound. Recommended.
The Mcap Supreme EVO serie by Mundorf uses the EVO winding method which takes advantage of two non-symetric axis for a better precision and great dynamics (upgraded pulse response). It also benefits from the technological Mcap Supreme build which removes residual inductance and promotes a tremendously realistic audio scene.
The result is a very efficient capacitor that is more affordable than Mcap Supreme & Mcap Supreme Oil series.
It combines the EVO capacitor precision with the famed 'liquid sound' from Mcap Supreme.
This reference is ideal for building, designing, repairing or upgrading any high-quality speaker system. It will provide best result with Accuton, SEAS, Scanspeak Revelator, Morel, JBL PRO, TAD.
All units are mm
Capacity | 0.22µf |
Dielectrics | Polypropylene (PP). |
Aluminium metalization | 99,99%. |
Dlielectric losses | 0,0002 à 1 kHz, 0,0001 à 10 kHz. |
Max temperature | 85°C. |
Tension | 1000V |
Tolerance | +/- 2% |
Diameter (body) | ⌀26 mm |
Length (body) | 23 mm |
Diameter (wires) | ⌀0.8mm |
Length (wires) | Long : 50 mm Short : 35 mm |
Tolerance (%) |
Capacitor capacitance (µF) |
Rated voltage (V) |
Capacitor type |
Capacitor format |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
