MUNDORF MCAP SUPREME Capacitor 600V 5.6μF
4.8 / 5
Reference : 1009
30,90 €tax incl.
25,75 € tax excl.
Shipping date: 16-07-2024.
The Mcap Supreme is an internationally recognized ultimate capacitor.Its remarkable sound qualities are obtained through a combination of advanced techniques:- A winding technology without inductance : Two coils are interlaced in the capacitor, so that the inductors are eliminated reciprocally. These two coils are connected in series. This means that for the production of a 1μF Mcap Supreme capacitor, two 2μF coils are used, which would give 4μF for a conventional capacitor.
- Use of the best materials : the polypropylene sheet used for Mcap Supreme is characterized by a minimal loss.
- Robust plastic and aluminum housings : This prevents micro feedback and retains important signal details
The results of listening justify all the effort that we put in the MCap SUPREME.
No capacitor gives as much spacialization and perfect reproduction of the finest musical nuances. You can use MCap SUPREME in any audio application that requires high-precision filtering, the result
will always be surprising and convincing. Expect a new dimension of musical reproduction. This effect is also remarkable with modest speakers!
For a great audiophile experience, try this capacitor!
DielectricPolypropylene
Tolerance±2%
Dielectric lossTan = 0.00002 à 1kHz & 0.00001 at 10kHz
Capacity5,6µF
Voltage600VDC
Body Diameter36 mm
Body Length56mm
Wiring Diameter1,4 mm
Wiring length60mm
Tolerance (%)2.0
Capacitor capacitance5.6
Rated voltage (V)600.0
Capacitor typeFilm capacitor
Capacitor formatAxial
4 reviews
les condos c'est jamais simple
celui ci est probablement l'un des tous meilleurs
This review has been posted for MUNDORF MCAP SUPREME Capacitor 600V 5.6μF
excellent produit .A consommer sans modération
excellent condo
condo sur mes 2 17Z0 ,medium plus aeré ,sa respire,belle transparencebasse plus tendu,,et moins projeté, a recommander avec les audyn cap.
REMARQUABLE...L'écart se creuse terriblement avec la MCap 400v : le haut-médium est enfin débarrassé de toute acidité laissant place à une aération époustouflante,douceur,silence entre les notes,j'ai changé d'enceinte en une seule soudure! A associer à une résistance MRSuprême car leur mariage est terrible!!
