Capacitor 250V 1.5µF
Thanks to the latest winding technologies, Mundorf is able to manufacture its MCap ZN capacitors from ultra-pure, RoHS-compliant tinfoil. In the past it was necessary to add lead in order to obtain the required flexibility of the foil for capacitor winding. However, lead had a negative influence on the signal tone.
Thus, lead-free tinfoil means, in addition to the positive environmental aspects, an improved noise characteristic. The high conductivity ensures a lively sound reproduction of music.
Finally, the mass inertia of the tin foil prevents oscillations, which ensures a beautiful transparency and spatiality.
Product type | Capacitor |
Capacity | 1.5µF |
Voltage | 250VDC |
Tolerance | ±3% |
Dielectric | Polypropylene (PP) |
Electrode | Tin foil (6µm) |
Loss factor | 0.00002 @ 1kHz 0.00001 @ 10kHz |
Max temperature | 85°C (185°F) |
Dimensions | Ø21 x 40mm |
Wires diameter | Ø1mm |
Wires length | 35mm |
Tolerance (%) | 3 |
Capacitor capacitance (µF) | 1.5 |
Rated voltage (V) | 250.0 |
Capacitor type | Film capacitor |
Capacitor format | Axial |
