MUNDORF MCAP ZN Capacitor 630V 0.1μF
Thanks to the latest winding technologies, Mundorf is able to manufacture its MCap ZN capacitors from ultra-pure, RoHS-compliant tinfoil. Their high conductivity ensures lively sound reproduction of music.
Reference : 4026
12,90 €tax incl.
10,75 € tax excl.
Mundorf MCap ZN
Capacitor 630V 0.1µF
Mundorf MCap ZN Condensateur 100V 2.7µF
Thanks to the latest winding technologies, Mundorf is able to manufacture its MCap ZN capacitors from ultra-pure, RoHS-compliant tinfoil. In the past it was necessary to add lead in order to obtain the required flexibility of the foil for capacitor winding. However, lead had a negative influence on the signal tone.
Thus, lead-free tinfoil means, in addition to the positive environmental aspects, an improved noise characteristic. The high conductivity ensures a lively sound reproduction of music.
Finally, the mass inertia of the tin foil prevents oscillations, which ensures a beautiful transparency and spatiality.
Product typeCapacitor
Capacity0.1µF
Voltage630VDC
Tolerance±3%
DielectricPolypropylene (PP)
ElectrodeTin foil (6µm)
Loss factor0.00002 @ 1kHz
0.00001 @ 10kHz
Max temperature85°C (185°F)
DimensionsØ12 x 25mm
Wires diameterØ0.8mm
Wires length30mm
Tolerance (%)3
Capacitor capacitance (µF)0.1
Rated voltage (V)630.0
Capacitor typeFilm capacitor
Capacitor formatAxial
Top capuchon
Utilisé en bypass couplé avec du Jantzen Zcap ce petit capuchon apporte de la dynamique, du détail, du gain avec des transitoires plus précises, à utiliser sans modération.
This review has been posted for MUNDORF MCAP ZN Capacitor 630V 0.1μF
Thanks to the latest winding technologies, Mundorf is able to manufacture its MCap ZN capacitors from ultra-pure, RoHS-compliant tinfoil. Their...
