MUNDORF N250 Zero Ohm Self Coil 0.68mH
These coils are recommended for filtering bass speakers. Their low impedance improves impulse response for a loudspeaker with better handling.
Reference : 13615
169,00 €tax incl.
140,83 € tax excl.
Last items in stock !
Shipping date: 25-04-2025.
Mundorf N250
Self Coil Zero Ohm 0.68mH
Mundorf N250 Self Bobine Zéro Ohm 0.68mH
Mundorf Zero Ohm Coil (ZOC) chokes are transformer-format coils. These are made of Feron, a high quality material that minimizes induced distortions.
In these Zero Ohm Coil, the central space is calibrated and adjusted between the two laminar nuclei: one in the shape of an L and the other in the shape of an E. The volume of the central space determines the inductance of the coil and requires great care in the manufacturing process. It should not be too small, in which case saturation effects could occur at high load.
Product typeSelf Coil
Coil wire materialSolid Core OFC Copper
Coil wire diameter2.5mm
Core materialFeron
Inductance0.68mH
Tolerance± 5%
Inductance (mh)0.68
