By buying this product you get 25 loyalty points
Zero Ohm Self Coil
Zero ohm coil ""Zero Ohm Coil"" (ZOC) is a coil transformer format.
It is made of FERON, a material with high electronic qualities that minimizes induced distortions.
The central spot of a ZOC is calibrated and adjusted by hand between two laminar rings (a L-shaped and a E-shaped).
The volume of the central space determines the inductance of the coil which demands enormous precision in the manufacturing process to ensure there will be no saturation at high load.
These coils are especially suitable for filtering your bass speakers. Their low impedance improves the impulse response (better light Speaker).
All dimensions are given in millimeters (mm)
Inductance | 12mH |
Tolerance | 5% |
coil wire diameter | 3.00mm |
Core | Feron |
Material | OFC 99.99% pure |
Dimensions | 130 x 115 x 97 |
