By buying this product you get 71 loyalty points
Silver Foil Coil 0.12mH
Metal foil coils are physically the best designed. The output quality is consistent up to 100kHz and unwanted capacitive loads are very low. The stability of the coil is also remarkable: thanks to the large contact area between the winding and the polypropylene insulator, vibrations are eliminated.
Foil coils generate much less vibration, which allows for music reproduction with extremely low distortion. Combined with their excellent electrical properties, these coils reproduce a more dynamic and clearer sound than conventional coils.
Product type | Foil coil |
Conductor material | Silver 1.19mm² |
Inductivity | 0.12mH |
Tolerance | ±2% |
DC Resistance | 0.09Ω |
Diameter | Ø35mm |
