MUNDORF VN180 Zero Ohm Self Coil 10mH
The Zero Ohm Coil (ZOC) is a transformer format coil. It is made of Feron, a material with high electronic qualities that minimizes induced distortions.
Reference : 19879
145,00 €tax incl.
120,83 € tax excl.
Shipping date: 15-04-2025.
Mundorf VN180 Zero Ohm Self Coil 10mH
Photo de la bobine Mundorf VN180 zéro ohm 10mH
The Zero Ohm Coil (ZOC) is a transformer format coil. It is made of feron cores, a material with high electronic qualities that minimizes induced distortions.
The central spot of a ZOC is calibrated and adjusted by hand between two laminar rings (a L-shaped and a E-shaped). The volume of the central space determines the inductance of the coil which demands enormous precision in the manufacturing process to ensure there will be no saturation at high load.
These coils are especially suitable for filtering your bass speakers. Their low impedance improves the impulse response.
Product typeZero Ohm coil
Conductor materialPure OFC Copper
NoyauFeron
Inductance10mH (+/- 5%)
Resistance DC0.16 Ohm
Wire cross-section2.55mm² (AWG 13 - Ø1.80mm)
Winding fixationRésine
Coil body typeN96
Dimensions96 x 86 x 84mm
Package1x MUNDORF VN180 Zero Ohm Self Coil 10mH
Inductance (mh)10.0
The Zero Ohm Coil (ZOC) is a transformer format coil. It is made of Feron, a material with high electronic qualities that minimizes induced...
