MUNDORF MRESIST CLASSIC Resistor 10W 2.2 Ohm
Mundorf MResist Classic resistors offer very good performance. They are similar but slightly simpler in construction than the MResist Supreme resistors. The MResist Classic series is designed to bridge the gap between ordinary MOX resistors and the top-of-the-line MResist Supreme.
Reference : 16096
7,50 €tax incl.
6,25 € tax excl.
Shipping date: 07-02-2025.
Resistor 10W 2.2Ω
Mundorf MResist Classic Résistance
Mundorf MResist Classic resistors offer very good performance. They are similar but slightly simpler in construction than the MResist Supreme resistors. The MResist Classic series is designed to bridge the gap between ordinary MOX resistors and the top-of-the-line MResist Supreme. The Mundorf MResist Classic shares the essential features of the advanced Supreme series, except for the two-wire winding.
Product typeResistor
Resistance2.2Ω
Power10W
DimensionsØ10 x 45mm
ConnectorsØ0.8 x 38mm
Temperature coefficient±50ppm/°C
Inductivity0.83µH
Dielectric strength1000VAC
Temperature range-40°C / +275°C
Conductor materialCopper-Nickel
Core materialCeramic / Centohm®
Resistance (Ohm)2.2
Tolerance (%)N/A
Power (W)10.0
Top mais fragile
Utilisée pour remplacer des resistances sables sur un filtre passif, cette resistance ouvre le son, comme si on enlevait un couvercle. Attention elles sont fragiles. Je conseille vivement.
This review has been posted for MUNDORF MRESIST CLASSIC Resistor 10W 2.2 Ohm
Mundorf MResist Classic resistors offer very good performance. They are similar but slightly simpler in construction than the MResist Supreme...
