MUNDORF MRESIST SUPREME MRES20-0,47 Resistor 20W 0.47 Ohm
The Mundorf MResist SUPREME range of resistors offers products of exceptional quality. With a real impact on sound reproduction, these resistors allow finer details and much better spatialization.
Reference : 14450
16,90 €tax incl.
14,08 € tax excl.
Shipping date: 25-04-2025.
Mundorf MResist Supreme MRES-0.47
Resistor 20W 0.47Ω
Mundorf MResist Supreme MRES-0.47 Résistance 20W 0.47Ω
The structure of this resistor composed of two wires 1Ω wound around the high temperature resistant cement allows the inductance to be constantly maintained below 75µH.
In addition, the resistors of the MResist SUPREME range also allow a very neutral sound reproduction, close to reality. This is made possible by a special, manually applied, fire-resistant moulding compound, which optimises and stabilises the winding of the resistor and protects it from microphonic effects.
Finally, in order to guarantee high quality sound even with high loads, a special Copper/Nickel alloy is applied as conductor with a positive and extremely low temperature coefficient of 50ppm/°C.
Product typeResistor
Resistance value0.47Ω ±2%
Power20W
Body dimensionsØ11 x 51mm
Wire dimensionsØ1 x 30mm
Resistance (Ohm)0.47
Tolerance (%)2
Power (W)20.0
magique
je ne pensai pas qu'une simple résistance puisse apporter autant et ce sur toute la bande, je les ai utilisé pour finaliser un projet st helens sur base du haut-parleur mark audio chn 110 ces résistances sont exceptionnelles tout est dit dans la description
This review has been posted for MUNDORF MRESIST SUPREME MRES20-0,47 Resistor 20W 0.47 Ohm
The Mundorf MResist SUPREME range of resistors offers products of exceptional quality. With a real impact on sound reproduction, these resistors...
