Excellent component, great value. Clears the details and lifts the transparency up to highest level in crossover application.
The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these resistances allow to obtain finer details and a much better spatialization.
Resistor 20W 3.9 Ohm
The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution. This type of resistance allow finer details and a much better spatialization.
The structure of this resistance is composed of two wires 1Ω wound around a heat-resistant cement, this design stabilizes the inductance and maintains its value under 75µH.
Moreover, the resistors of the MResist SUPREME range are very useful for electronic systems designed for a deep neutrality in the sound reproduction. Thanks to a fire-resistant special molding compound, the resistance winding is stable and maintained in its optimal position, thus preventing the circuit from microphonic effects.
Finally, to guarantee a high quality sound even with heavy loads, a special Copper/Nickel alloy is applied as conductor with a positive and extremely low temperature coefficient of 50ppm/°C.
Resistance | 3.9 ±2% |
Power | 20W |
Body dimensions of the resistance | 51 x ⌀ 14.4mm |
Wires dimensions | 40 x ⌀ 1mm |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
