MUNDORF MRESIST ULTRA Resistor 30W 1.5 Ohm
The development of Mundorf MResist Ultra resistors is based on the excellent tonal properties of the copper-manganese foil. Compared to all wirewound resistors, this film offers lower inductance. The copper is significantly softer than the metal oxide used in MOX resistors.
Reference : 16124
26,90 €tax incl.
22,42 € tax excl.
Shipping date: 18-04-2025.
Mundorf MResist ULTRA
Resistor 30W 1.5Ω
Mundorf MResist Ultra Résistance
The development of Mundorf MResist Ultra resistors is based on the excellent tonal properties of the copper-manganese foil. Compared to all wirewound resistors, this film offers lower inductance. The copper is significantly softer than the metal oxide used in MOX resistors. The natural resonances of the copper-manganese foil are therefore much less pronounced, which means that the distortions caused by crystallurgy and electroacoustics are significantly reduced. This is the reason why Mundorf MResist Ultra resistors have gained a prominent place among audio components in recent years: They are free of many of the distortions inherent in other resistor designs.
Product typeResistance
Resistance1.5Ω
PowerIn free air : 3W
Fitted on a heatsink : 30W
Dimensions15.5 x 21.1 x 4.6mm
Connectors1.4 x 11.7 x 0.8mm
Temperature coefficient±30ppm/°C
Inductivity< 0.075µH
Dielectric strength500VAC
Temperature range-40°C / +130°C
Conductor materialManganin®
Core materialCuivre / PPS
Resistance (Ohm)1.5
Tolerance (%)N/A
Power (W)30.0
fantastica resistenza
Ho usato di tutto, anch ele mundorf supreme.
ma qui siamo al top del top.
Abbianoto al proprio radiatorino presu su audiophonics ha una resa incredibile. Nulla di più preciso, trasparente, perfetto.
Evidenzierà ogni particolare della riproduzione sonora senza filtri. Evidenzierà i limite del vostro impianto ma vi esorterà a trarne più benefici.
Nel mio caso è comparsa dopo il suo uso una leggera fitica d'ascolto rispetto la serie Supreme Mresit.
Da fare una colpa? NO! Il limite dell'impianto e la risoluzione ne ha giovato. Ho Migliorato l'impianto aggiunggendo alimentaotre lineari (grazie audiophonics), uso Ian canada su DAC, scheda USB, pc, router, switch nas. Il risultato ora grazie a queste resistenze è formidabile! Dopo le alimentazioni lineari ho potuto pure aumentare il livello di fine tuning, cavi segnale, usb potenza, alimentazione in modo molto spinto godendo di una riproduzione nel tempo sempre migiorata.
Le consiglio, prima di loro a volte certi upgrade erano vani. Mi hanno aperto la strada verso il paradiso.
This review has been posted for MUNDORF MRESIST ULTRA Resistor 30W 1.5 Ohm
The development of Mundorf MResist Ultra resistors is based on the excellent tonal properties of the copper-manganese foil. Compared to all...
