MUNDORF MRESIST ULTRA Resistor 30W 0.12 Ohm
The development of Mundorf MResist Ultra resistors is based on the excellent tonal properties of the copper-manganese foil. Compared to all wirewound resistors, this film offers lower inductance. The copper is significantly softer than the metal oxide used in MOX resistors.
Reference : 16111
17,50 €tax incl.
14,58 € tax excl.
This product is temporarily unavailable.
Mundorf MResist ULTRA
Resistor 30W 0.12Ω
Mundorf MResist Ultra Résistance
The development of Mundorf MResist Ultra resistors is based on the excellent tonal properties of the copper-manganese foil. Compared to all wirewound resistors, this film offers lower inductance. The copper is significantly softer than the metal oxide used in MOX resistors. The natural resonances of the copper-manganese foil are therefore much less pronounced, which means that the distortions caused by crystallurgy and electroacoustics are significantly reduced. This is the reason why Mundorf MResist Ultra resistors have gained a prominent place among audio components in recent years: They are free of many of the distortions inherent in other resistor designs.
Product typeResistance
Resistance0.12Ω
PowerIn free air : 3W
Fitted on a heatsink : 30W
Dimensions15.5 x 21.1 x 4.6mm
Connectors1.4 x 11.7 x 0.8mm
Temperature coefficient±50ppm/°C
Inductivity< 0.075µH
Dielectric strength500VAC
Temperature range-40°C / +130°C
Conductor materialManganin®
Core materialCuivre / PPS
Resistance (Ohm)0.12
Tolerance (%)N/A
Power (W)30.0
The development of Mundorf MResist Ultra resistors is based on the excellent tonal properties of the copper-manganese foil. Compared to all...
