Condensateur utilisé dans un amplificateur à tube pour le couplage. (Tube de puissance. Finesse des timbres, détails des harmoniques, douceur de la scène sonore. Je recommande vivement.
Capacitor 1000V 0.33µF
Mundorf MCap Supreme Silver Oil are capacitors with an oil-impregnated metallized polypropylene dielectric. As the name suggests, high purity Silver is used for the capacitor coating and the winding is impregnated with a special oil that has been developed through extensive testing and listening. These characteristics contribute to a more complete and softer tonal richness and diversity. The metallized Polypropylene foils allow to maintain extremely low tolerances that cannot be reached with traditional oil/paper capacitors.
It is also the first time that the advantages of oil-impregnated capacitors are successfully combined with the long-term stability of metallized paper and internal wiring in series for induction-free performance.
These capacitors allow a lively sound reproduction, thanks to subtle dynamics, high precision and fine details.
Product type | Capacitor |
Capacity | 0.33µF |
Voltage | 1000VDC |
Tolerance | ±5% |
Dielectric | Polypropylene (PP) |
Metallization | Silver |
Loss factor | 0.0002 @ 1kHz 0.0001 @ 10kHz |
Max ambient temperature | 60°C (140°F) |
Dimensions | Ø19 x 39mm |
Wires diameter | Ø1mm |
Wires length | 60mm |
Tolerance (%) | 5.0 |
Capacitor capacitance | 0.33 |
Rated voltage (V) | 1000.0 |
Capacitor type | Film capacitor |
Capacitor format | Axial |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jeanphilippe c.
