MUNDORF TUBECAP Capacitor 750V 20µF
Mundorf Condensateur TubeCap 750V 20µF
These capacitors combine high dielectric strength with low residual inductance. They have been developed to offer a high quality alternative to high voltage electrochemical capacitors and are therefore ideal for use in tube amplifiers.
Reference : 2034
26,90 €tax incl.
22,42 € tax excl.
Shipping date: 16-07-2024.
Mundorf TubeCap
Capacitor 750V 20µF
Mundorf TubeCap Condensateur 600V 30µF
Mundorf TubeCap capacitors are made from a Polypropylene film with special features. It is particularly thin and self-healing. This allows TubeCap capacitors to achieve a higher maximum operating voltage with rather compact dimensions.
Product typeCapacitor
Capacity20µF
Voltage750VDC
Tolerance±5
ESR @ 10Hz10mΩ
ESL @ 500kHz17nH
DielectricPolypropylene (PP)
Loss factortan ∂ < 0.005 @ 1kHz
Failure rate1 fit
Sealing compoundPU UL 94-V0
Useful life100000h @ hot spot 60°C
Cover0.5 x Un ; 40°
Max ambient temperature85°C (185°F)
Dimensions55 x 35 x 30mm
Wires diameter1mm
Wires spacing30mm
Tolerance (%)5.0
Capacitor capacitance20
Rated voltage (V)750.0
Capacitor typeFilm capacitor
Capacitor formatRadial
filtrage alim
Excellents résultats sonores en filtrage d'alimentation sur un préampli à triode à chauffage direct. Cela joue sur la finesse, un meilleur suivi mélodique, plus de propreté mais sans salir les aigus. Bien meilleur qu'un PP de base. Cher mais en vaut la peine. À installer dans les endroits stratégiques de l'alim, comme en tête de Pi par exemple. Ici il est placé comme dernière capa de découplage de l'anode. Prévoir la place car c'est assez encombrant.
This review has been posted for MUNDORF TUBECAP Capacitor 750V 20µF
These capacitors combine high dielectric strength with low residual inductance. They have been developed to offer a high quality alternative to...
