ALLO DIGIONE PLAYER Streamer Raspberry Pi 4 Digital Interface DigiOne Volumio Pre-Installed Black
The Allo DigiOne Player is a digital player with network support. It is therefore able to play your audio files from a remote source. This source can be a hard drive within the network or even an online streaming service.
Reference : 14390
249,00 €tax incl.
207,50 € tax excl.
Allo DigiOne Player
Streamer Raspberry Pi 4 B Digital Interface DigiOne Volumio Pre-Installed Black
Allo DigiOne Player Lecteur Réseau Raspberry Pi 4 Interface Digitale DigiOne Volumio Pré-Installé Noir
Access your audio files without going through a computer
With no screen and no control interface, this player can be remotely controlled from a mobile phone, tablet, computer or any device capable of running a web browser. This means you can enjoy great audio playback with convenient remote control.
Raspberry Pi 4 - 4 GB
This version of the Allo DigiOne Player is based on an SBC (Single Board Computer) Raspberry Pi 4 B. This mini computer is equipped with capabilities perfectly suited for audiophile use with its Quad Core 1.5GHz processor, 1GB RAM and native high performance network connectivity (WiFi, Bluetooth).
Despite its compactness, this device has all the capabilities to play high quality audio files, including the more demanding audiophile formats in terms of computing power and memory.
DigiOne S/PDIF interface
The Raspberry Pi card is surmounted by an Allo DigiOne digital interface. This high-performance digital audio module is now recognized in the audiophile world, notably thanks to its excellent price/performance ratio. It extends the capabilities of the Raspberry pi card and allows it to output the digital audio stream via a BNC output and an RCA output.
With its two internal clocks, the DigiOne interface offers a remarkably clear signal, as evidenced by its extremely low jitter rate of 0.4 picoseconds. As the jitter is picked up by all elements of the system and is difficult to erase at the cost of further signal inaccuracies, this feature makes the DigiOne a perfect choice for a high-fidelity digital player.
Dedicated audio player
Used in a hi-fi system, this type of network drive is extremely practical since it is infinitely more compact than a conventional computer and thus limits the space occupied. Wireless connectivity is also a real asset, to reduce clutter due to cable clutter. Conversely, all of its computing power and computer construction are mobilized to serve audio quality. The sound quality will therefore be multiplied in comparison with that offered by a smartphone or a conventional tablet.
This way, your communication and work devices avoid being solicited for precarious audio use and remain available for their other functions: no more phone ringing in the middle of an opera or computer updating during a guitar solo. The network player, on the other hand, has only an audio function and will therefore have no excuse to disturb the listening experience.
Volumio, advanced audio software pre-installed
Unlike many network players based on an SBC such as Raspberry Pi, this DigiOne Player is already equipped with a pre-installed audio software solution. Therefore no Linux installation or Micro SD card flashing skills are required. The device is ready to use and all that is left to do is connect it to your network to take advantage of its extensive capabilities.
Volumio is a software solution developed with the aim of providing excellent audio performance while offering an intuitive and ergonomic interface that is particularly easy to use. This software exploits the full hardware capabilities of the Raspberry Pi, in particular its connectivity, since it offers the possibility to control the player from any device capable of connecting to a web browser (computer, smartphone, tablet...). It is therefore very easy to browse through your audio files, change playback options or volume from anywhere, as long as a network connection exists.
To go even further and extend the capabilities of the device, Volumio is also able to manage a WiFi hotspot, i.e. to set up an ad-hoc network if the fixed network fails. This means that the device will still be able to play your audio library, even if your router/internet box fails. On the other hand, it also allows the network player to be moved to be used in private network locations.
Open Source and the freedom to choose
The tradition of SBC is singularly articulated around the notion of Open Source. Devices and software solutions compatible with Raspberry Pi are no exception to the rule and you will be able to easily change the software installed on your network drive if you wish to experiment with other solutions and functions.
This network player will work just as well with Max2Play, DietPi or piCorePlayer depending on your audio projects. Simply extract the Micro SD card and flash it with the software image of your choice.
It is recommended to use the Allo Shanti power supply for best performance (sold separately, see accessories).
Product typeStreamer
Raspberry Pi version4 B - 4GB
CPUBroadcom BCM2711 ARM Cortex-A72
Quad Core 1.5GHz
RAM1Go
Raspberry Pi connectors2x USB-A 3.0
2x USB-A 2.0
1x RJ45
2x Micro HDMI
1x Jack 3.5mm
Raspberry Pi wireless connectivityWiFi IEEE 802.11b/g/n/ac 2.4GHz et 5GHz
Bluetooth 5.0
GPUBroadcom VideoCore VI, openGL ES 3.0
Digital interfaceHAT Allo DigiOne
DigiOne outputs1x S/PDIF BNC
1x S/PDIF Coaxial
Galvanic insulation
Noise50uV
Oscillators2x NDK
Jitter0.411ps
Power5V (Power supply NOT included)
Case materialAcrylic
ColorTranslucent black
InputWiFi
InputRJ45
OutputCoaxial SPDIF
OutputMicro HDMI
OutputJack 3.5mm
OutputBNC
DAC / ADC ChipNC
Max sampling rateNC
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsWeb radios
4 reviews
Excellent
Il remplace un lecteur RaspDIGI Digipi+ V2 qui n'est d'ailleurs plus dispo chez Audiophoncs, la différence est audible, finesse et détail sans pour autant provoquer de fatigue auditive. Le faible Jitter est sans doute le facteur déterminant. De fait, après comparaison, j'ai abandonné (définitivement ?) l'amplification classe D à précision chirurgicale pour revenir à du plus classique (Classe A/B de bonne facture et DAC à puces AKM) sans perdre de détail et avec la scène sonore de l'enregistrement . Ce n'est que du plaisir, mes fichiers numériques sont tous une redécouverte. Audiophonics propose toujours d'excellents produits qui ne sont pas nécessairement couteux. Ce n'est pas parce qu'il faut suivre la "révolution numérique" qu'il faut partir dans du matériel à 4 000 € et plus, proposés par certains vendeurs...
This review has been posted for ALLO DIGIONE PLAYER Streamer Raspberry Pi 4 Digital Interface DigiOne Volumio Pre-Installed Black
Allo Digione Player Raspberry Pi 4 avec alimentation Allo Shanti
Après avoir installé le kit EvoDac avec Raspberry PI 4 dont les résultats étaient déjà excellents, mon souhait était ensuite d'installer un DIRAC Live numérique.
Pour ce faire, ce Dirac (à venir) devra être installé entre deux sources numériques, d'ou l'acquisition du Allo Digione player Raspberry PI 4 avec son alimentions Allo Shanti, directement branché sur le EVO DAC.
Les résultats sont impressionnants au niveau des différents critères auditifs. Nous gagnons encore en profondeur de champ auditif, aération holographique, définition, assise et impact des graves et bien sûr en musicalité.
Toute ma reconnaissance pour les conseils et assistance des personnes d'audiophonics, qui n'ont pas ménagé leur effort pour m'aider à cette installation dans mon système actuel.
Excellent product
I think this could be the best streamer (and server) for this price point. I came from a GCA and it was good but I need something better and more flexible. I’m totally satisfied.
excellent !
Tout est prêt, monté, la carte SD avec la distrib dessus ...
En fait, il n'y a plus qu'à brancher !
Je l'utilise dans ma chambre en wifi, la sortie coax va sur un FDA SMSL Q5, relié à des clones de LS3-5.
Mes fichiers audio sont sur un NAS (qu'il reconnait du premier coup), et j'utilise Spotify (grâce aux Plug-In de Volumio).
L'ensemble est géré à distance par n'importe quel smartphone ou tablette.
Pas un plantage depuis son installation (qui d'ailleurs s'est déroulée sans aucun problème).
Au vu de l'encombrement ridicule et le prix extrêmement modéré du boitier, je ne vois pas comment il serait possible d'avoir mieux comme serveur audio.
L'ensemble (Allo Digione Player + FDA + Clone Rogers LS3-5) est à la fois extrêmement performant, bon marché et prend peu de place
Les seuls point critiquables sont :
- le Rasp 4 a tendance à chauffer (mais ça reste raisonnable)
- il n'y a pas d'interrupteur pour mettre le boitier hors tension.
- quelques soucis avec le transporteur (livraison GLS), mais Audiophonics est au courant et fait le nécessaire
The Allo DigiOne Player is a digital player with network support. It is therefore able to play your audio files from a remote source. This source...
